XR7 Dave
There's been a lot of talk about T56's over the years, but finally we are going to put one in, get the job done, and let you know what it feels like.
Ok, in all honesty you may never actually complete a total install in one weekend without a lot of groundwork being done in advance, but the actual installation is quite doable.
Here we go.
First off, the ground work:
You'll need - A working T56. In this case we took an early Camaro Borg Warner T56 and updated the front cover and input shaft to a late model so that it would accept a diaphram style slave cylinder which we purchased in advance from McLeod along with a SBF bellhousing/SFI blowshield and separator plate. We used a custom McLeod lightweight billet steel flywheel and in this case a twin disc McLeod clutch originally designed for a 4.6L Cobra. Then we had to make sure we had all the right attaching bolts (none of the stock stuff or anything that came in any of the kits worked) and clutch line adapters for the master cylinder and -3 AN lines. Then you'll need a special lengthened driveshaft which we had custom made by Dynatech. I also made, in advance, a custom bolt in crossmember from a modified stock SC unit as can be seen in the pictures. A Z-handle on the stock Camaro shifter took care of boot alignment as the pictures show, requiring only minor trimming of the transmission tunnel.
More to come! As the weekend progresses......
All of that was handled in advance, and
Here we go.
