well it was a while ago i decided on the radio and dvd combo but i havent got around to doing the rest of my stereo until recently so i decided to fire everything up this weekend to see how it sounds. i also decided it was a good time to put in my gauges. i was already going to get boost, water, and oil, and since my speedometer stopped working i decided to do them all. so i remade the gauge panel, threw in the turn signals, high beam, and check engine lights. i also wanted gauges that matched my radio color so i went with the autometer cobalt gauges, the blue matches perfect with the radio. i will try to get a picture when it gets dark. i used a texture paint for the gauge panel that i usually like but on this application it didnt do it for me so i will probably redo the paint when i add one more gauge, as you can see by the empty hole. i also had to modify the dash quite a bit in order to fit the radio combnation that i wanted and then made a flush trim fro the radio using the factory piece. it is no where near finished more in a pre primer and paint stage, but i will do all that when i finish with the rest of the panels im making in the interior and trunk. i still havent come up with a paint scheme for the car so that will all be done at the same time. i just wanted to post this because there arent a lot of pictures being shown for the gauges and dash so i dont know if there are any guys out there with some different things going on. hopefully this will give everyone some ideas. im just glad i was able to accomplish something over the weekend and i have a stereo working again. i still have to calibrate the speedometer but all the other gauges are working great. hurray for me...
