Yes, Prior Remanufacturing at 972-494-4254. They are $99.95 + UPS. I just put mine on yesterday. Be aware, they do not have a wrench fitting on them to tighten them with. You'll need an oil filter wrench or something of that nature to tighten it with. Make sure you've got something that will work before you start. I questioned them about this and I was told that another company makes them and that is the way they come. They also advised not weld a nut on them as it would melt the diaphram inside. Also, there was an orfice in my original that is not in the new unit so I pried it out and swapped it over thinking that it is there for a reason. After pumping down the brakes 60 times there was still some pressure in the system so I did another 25. My new one seems to be doing fine and my pump doesn't cycle every time I hit the pedal anymore. The only time the light flashed was on a hard panic stop.
