94soupecoupe
so i replaced my lower control arm and ball joint cause i needed to. i also cut the rotors and put a new set of pads on also. and i replaced the belts and did an oil change as well. and i did the strut rod bushings also.
after doing my little overhaul today, my alignment is waaaayy off and when im in drive and holding the brake i move the wheel left to right and i get a knocking noise. and the car pulls really hard to the right, i have to hold the wheel to make the car go straight. if i let it go, it makes right hand turns.
could i just need a really good alignment? or did i mess something up somewhere.
thanks for the help
thanks for the help
