Results 1 to 10 of 10
Thread: Fluttering Speedo
    Aug 2005
    Sunrise Beach, MO
    2,289
    Question Fluttering Speedo
    As stated, in my 89 the speedo has begun to flutter when im stopped it will bounce all around and even rack up miles!!!
    So, Ive been having a problem with my fuel gauge and decided to change out Anti-Slosh module due to my gauge moving around..Thats when I noticed whenever my speedo jumps around my fuel gauge moves SLIGHTLY up towards F then back down...
    Any ideas fellas, been trying to chase this forever
    Thanks,
    Tony
    [B][COLOR="Blue"][COLOR="Red"]June 6, 2009....D-Day[/COLOR][/COLOR][/B]
    [B][COLOR="Blue"]1989 SC AUTO- Midnight Blue:D[/COLOR][/B]
    "They act like they are bed buds that have known me forever" -Corey B-
    Aug 2005
    Sunrise Beach, MO
    2,289
    Anyone??
    Salem OR
    7,491
    I'd be looking at the main board that holds all the guages - cracks, cold-solder joints, corrosion, busted connectors/leads, etc. Do you happen to have a spare cluster to try?
    Aug 2005
    Sunrise Beach, MO
    2,289
    No spare cluster, it just does it when sitting still, if i start moving it works normal, and is accurate
    Salem OR
    7,491
    In that case, I'd be looking at the source/sender.
    Aug 2005
    Sunrise Beach, MO
    2,289
    Is it located on the side of the tranny?
    VSS??
    Salem OR
    7,491
    Auto or manual?
    Try the tailshaft, driver's side...
    But you know, when multiple devices start acting up, the culprit is frequently bad grounds.
    Aug 2005
    Sunrise Beach, MO
    2,289
    Auto or manual?
    Automatic, where should i look at grouns
    Salem OR
    7,491
    Cruise control equipped...?
    In the case of the SC, know that there are medium sized additional ground leads at the passenger side, front, that lead from near the motor mount, over to the body (see photo), one from the passenger side hood hinge to the hood and of course the grounds at/near the battery. There are also ground-clusters that sit on the front of the header panel, just behind each headlight. Not to mention several additional smaller grounds throughout the body.
    One way to approach troubleshooting grounds is to add your own for testing. I'd start by patching in a temporary ground lead between the gauge cluster, and the battery negative terminal. Don't try this unless you feel comfortable with the process
    Aug 2005
    Sunrise Beach, MO
    2,289
    Yes, CC Equpt
    Oh im comfortable, ill be working on the planes you fly in, in about 6 months
    And I just needed a starting point, Thanks KMT
    -Tony
  1. 21 tooth speedo gear
    By doug93sc in forum Technical Forum
    Last Post: 10-05-2005, 02:07 PM
  2. speedo and rearend gear question
    By x182dan in forum Technical Forum
    Last Post: 02-19-2005, 04:17 PM
  3. Speedo Dots
    By TBSCoupe in forum Non Technical Forum
    Last Post: 02-22-2003, 10:18 PM
