Results 1 to 2 of 2
Thread: leaking slave cylinder
    Maumee, Ohio
    275
    the leak on my 91 seems to be getting worse.
    I have checked all the lines the best I could and see no leaks there.
    I pulled the rubber access cover off the side of the bellhousing and I can see that the outer part that moves when the clutch pedal is moved in and out is very oily and dirty. The lines that connect inside the bellhousing are dry. Is there some seal or another on the slave that could have let loose?
    Thanks
    Ron
    Apr 2003
    California
    358
    Verify that the bleed valve on the slave is tight.
    MB
  1. new clutch kit and slave cylinder for 89-93 t-bird
    By fast bird in forum Parts for Sale
    Last Post: 06-08-2006, 03:00 PM
  2. Replies: 5
    Last Post: 07-23-2005, 01:49 PM
  3. Clutch slave cylinder intermittent leak...
    By cap320 in forum Technical Forum
    Last Post: 06-21-2005, 01:14 PM
  4. Clutch slave cylinder connector.
    By SCCoupe50 in forum Technical Forum
    Last Post: 05-23-2005, 11:42 AM
