Results 16 to 29 of 29
Thread: 17" Front Runner Option
    Oct 2005
    2,285
    Quote Originally Posted by JeepsterSC View Post
    The LS spares are 5 on 4.5 bolt pattern?
    2000 - 2008 Lincoln LS 5 lug 4.25 inch or 108mm
    Jim, SCCoA Member#: 2789
    "cuz Jim has mad skillz, yo!" Melon.
    "You guys crack me up talking about nitrous when you don't even know if you can keep it together on gasoline." XR7 Dave
    "I didn't break it, I found it's weakness."
    Oct 2005
    2,285
    Quote Originally Posted by moovn2vegas View Post
    sure hope you dont have any probs w that wheel. think about what it was designed for, and max speed and miles that tire was rated for. be careful, they werent made for extended use or high speed! my 2 cents
    David is using his tires as spares.
    Thomas Aden, Ken Wagner and several other members have been using the LS RIM with a RACING tire at the track for years with no problems.
    20,948
    The 17" LS spares showed up today...Wow they are a lot bigger. The diameter wasn't a problem, but it was a snug fit getting it into the well. The problem is the additional width of the wheel and tire. It's nearly twice the width of the stock spare and sits about 1.5" higher than the floor of the trunk. I would like for it to sit flush, but really isn't a big deal for me because I don't usually carry anything in the trunk.
    PS: I'll post some pictures in the morning
    Overland Park, KS
    4,056
    Yeah, If I really wrestle it into the Mark VIII well it just barely fits top to bottom. The edge sits up slightly, but I have it tucked under the sub box so you can't really tell. I'm not sure how it compares to a MN12 in height.
    I assume you tried flipping it over to see which way fit best? I found face down to provide the closet fit.
    Thomas
    20,948
    Thomas,
    Face down fits the best but only because of the tire retention bracket. I could remove the jack to lower the edge closest to the bumper, but the hump in the bottom of the well on the fuel tank end is holding the other end up. Not sure what is directly beneath that portion of the well, and it may be possible to do a little sheet metal bending with a sledge hammer to get it to sit flush. I'm not really concerned, and just happy to have a spare tire.
    Here are a few pictures.
    Oct 2005
    2,285
    Good to know that they showed up OK and that you are happy with them.
    20,948
    Quote Originally Posted by TSC89 View Post
    Jim,
    They arrived in perfect condition, and yes I'm very happy with them. BTW, Those sure are some strange looking lugnuts.
    Thanks again, David
    Murrysville, PA
    1,259
    Do you think they will fit with the brembo calipers?
  9. #24
    Oct 2005
    2,285
    Quote Originally Posted by Tony8470 View Post
    I don't know about them fitting over the Brembo's. They might I just haven't seen anyone who has tried it.
  10. #25
    Aug 2004
    Batavia,OH
    2,019
    I bought one of those wheels on car-part.com for $35 shipped, I still need to get another.
    Alan
  11. #26
    Oct 2005
    2,285
    Quote Originally Posted by Dirtyd0g View Post
    Alan
    You did really good. Around here I am lucky to find the rim without a tire for $50. Others with crappy tires run $75 to $100.
  12. #27
    Aug 2004
    Batavia,OH
    2,019
    I had to do some searching and I saw a deal I couldn't refuse. That is why I only got one. The tire that comes on them you don't want anyway, no decent track will allow you to run on it.
    Alan
  13. #28
    Oct 2005
    2,285
    I wasn't buying them to run on the track, especially with the 60mph max speed limitation on most.
    I was buying for people like David and a couple of others who wanted a big enough spare to fit over our bigger brakes.
  14. #29
    Franklin,Mass
    402
    Quote Originally Posted by Cobrarthunder View Post
    Pre pollished...Clearance
    At the track...pollished
    I'm using hoosier front runners. Put together this about 4 years ago.
    FYI...you need to go buy 10 lug nuts for the LS or LS based thunderbird. They are a shank type and the stock conical lug nuts are not safe to use on these wheels.
    Chris
    Fixed the images for you!
    Joe
    It's not a 97 Sport, it just looks like one!
  1. Continued ABS woes (and others)
    By gregs90sc in forum Super Coupe Club of Ontario
    Last Post: 07-11-2007, 08:35 AM
  2. Front "SC" Bumper Cover
    By 93DirtyBird in forum Want to Buy
    Last Post: 02-23-2006, 02:47 PM
  3. Can you help with front brake question
    By Georgie in forum Technical Forum
    Last Post: 08-05-2005, 12:15 PM
  4. question about front end swaps
    By slot tech ty in forum Technical Forum
    Last Post: 10-02-2003, 11:10 PM
