Results 1 to 8 of 8
Thread: How long should it take to get to normal operating temp?
    Oct 2008
    105
    just took my 90 sc for a spin (so nice!)...it's been in a cold garage (almost freezing really).
    only after 20 min of driving did the coolant temp guage finally make it up into the lowest part of "normal". (heater was working ok after 5-10min)
    should it take this long to warm up? or is something buggered?
    Aug 2005
    Sunrise Beach, MO
    2,289
    normal i say
    [B][COLOR="Blue"][COLOR="Red"]June 6, 2009....D-Day[/COLOR][/COLOR][/B]
    [B][COLOR="Blue"]1989 SC AUTO- Midnight Blue:D[/COLOR][/B]
    "They act like they are bed buds that have known me forever" -Corey B-
    Salem OR
    7,491
    Yep, sounds about right.
    An easy 'service' tip if you are unsure about gauge action is to confirm that the push-on connector at the coolant temperature sender for the gauge is clean (same for the terminal) and grips firmly - squeeze it down in width a bit if needed. You're looking for the sender nearest the thermostat housing.
    Apr 2004
    sumter, south carolina
    3,050
    pull it out and look at it too. if its all gunked up its not gonna get a good reading.
    Oct 2008
    105
    will do thanks!
    Jul 2007
    South IL
    1,574
    takes my sc forever to warm up in the winter, i took a sheet of stainless steel and placed it over half the rad for winter driving, this will be its 2nd winter. other then that the sc just doesnt like to warm up. its a small engine with a big cooling system. just so its warm in the am i got a space heat built for child safety set to a timer so it turns on 30min before i need the car in the am. other then that good luck
    Dallas, TX
    5,755
    My black and red cars will warm up within 5 minutes. My white car... takes about 15 I have not been able to determine why. I have replaced thermostats, swapped ECT's, swapped EECs, swapped temp guage senders, radiators, flushed heater cores, and burped the coolant many times... and have not figured it out yet.
    Apr 2005
    Western New York
    485
    Thumbs up mine warms up within 5 min
    Of course i have a ower rad hose heater element. Since I have a custom 3 piece lower rad hose that goes from pump around the belt, behind lower part of IC and then forward to the drivers side of the IC where my huge rad oulet is. The heater element is a few inches before the pump inlet so the warm water can easily rise into the block rather than go downward and back up into the rad. Set to an outside "UL" rated timer about an HR before i have to go to work. Saves on fuel as the car runs less of the cold start stradigy.
  1. '94 SC A/C and Temp Gauge Issues
    By tedallen in forum Technical Forum
    Last Post: 07-04-2006, 05:41 PM
  2. Air Charge temps...What's a normal temp????
    By lube70 in forum Technical Forum
    Last Post: 05-21-2006, 08:01 PM
  3. normal operating temp...?
    By Blown 91 Bird in forum Technical Forum
    Last Post: 11-04-2005, 09:08 PM
  4. Auto Meter Dual Channel Air Temp Meters
    By 68COUGAR in forum Non Technical Forum
    Last Post: 09-07-2005, 12:28 PM
  5. LONG Cooling Issues.....again/still
    By mlbuxbaum in forum Technical Forum
    Last Post: 05-12-2005, 11:10 AM
