View Poll Results: Ethanol "Premium" or 100% Gasoline "Premium"
Voters
9. You may not vote on this poll
  • 93 Octane with Ethanol
    8 88.89%
  • 91 Octane "Pure Gas" no ethanol
    1 11.11%
Results 1 to 12 of 12
Thread: Is ethanol really that bad for an SC?
    Jun 2015
    South Carolina
    22
    I have religiously purchased "real" gas for my SC, fearing that ethanol would cause problems, leaks and painful bills. It was sort of a pay now or pay later decision. In retrospect, my SC has been very reliable over its 25 years, so I haven't had to "pay later." But - was that really necessary? If I switch to ethanol containing premium fuel now (almost $1/gallon cheaper than my current brew), will it really matter? Let's hear what the experts think.
    I'm trying to post a poll, but the options don't seem correct.
    5,143
    I'd save the bucks and go with the 93. Now if the cars sits for extended periods of time without going thru a tank of gas then use the non ethanol fuel.
    SCARlit on drag duty now
    1,530
    It isn't going to cause any problems in terms of creating leaks by itself. As was mentioned, if you leave the car sit for long periods of time, it can cause problems because ethanol absorbs moisture out of the air, and that moisture, if left in the tank for long periods, can cause components to rust. If you regularly drive the car, then the fuel is used up before it has a chance to absorb much moisture, so it is a non-issue. Really the only downside you will notice is a significant drop in gas mileage, probably to the tune of 2-3mpg. At 25 cents a gallon, that would probably be a wash, but if the E10 is $1/gal cheaper, then I would just run that and not worry about it. Only thing is if you are going to store the car at any time, run the tank almost empty and fill it to the brim with the straight gas before you do.
    May 2015
    68
    Ethanol is used to increase octane. What is used in the non ethanol blend? I had an idea that really don't know if its worth it or not, but I've thought of using non ethanol blend 93 oct and add 10% ethanol to it to raise octane. Don't know if it's worth it or not. Having a hard time finding home brew mixing chart for it.
    Nov 2012
    U.P
    720
    my cars ALWAYS ran better with 93 ethanol as compared to 91 w/o..smoother engine and better mileage..yes,i constantly kept track of mileage while taking long road trips..i even found 93 eth plus 2 bottles of dollar store oct booster and it would get an extra 20-30 miles to the tank.no bs either it was a constant plus every time i used them. sometimes though hard driving effected it of course but when id travel id grannygrain the entire time from point a to b.
    Sep 2014
    Broken Arrow, Ok
    195
    Quote Originally Posted by 20psiofevil View Post
    I run an E30 mix in my 13 EcoBoost F150. With 91 octane that gives me about 95 octane total. I'll find the chart I use.
    BTW, Ethanol not only gives you a higher octane but it has a cooling effect to.
    Apr 2018
    1
    Review
    I'd save the bucks and go with the assignment help. Now if the cars sits for extended periods of time without going thru a tank of gas then use the non ethanol fuel.
    Jan 2006
    Broad Run VA
    494
    I have primarily used Super Shell 93 octane for many years and found that the car gets better MPGs over any other brand of gas. The car mostly sits in the garage from December thru March. When a car sits for a storage period the gas tank should be as full as possible to reduce the accumulation of water in the tank. The less air in the tank the less moisture there is to collect from it. The other thing that can help for storage is to use a gas treatment that keeps the gasoline in phase so it will not separate into layers with the water being on the bottom of the tank.
    Red 94 5 Speed
    1 of 722
    2018 Carlisle 1st Place Winner, 94-95 SCs
    2014 Carlisle 3rd Place Winner, 94-95 SCs
    2013 Carlisle 1st Place Winner, 94-95 SCs
    2012 Carlisle 2nd Place Winner, 94-95 SCs
    Aug 2007
    110
    Where do you buy your gas that has so much water in it?
    Jan 2006
    Broad Run VA
    494
    Quote Originally Posted by r429460 View Post
    Gas does not usually have water in it unless it from a station that does not monitor their tanks for it. There is moisture in the air and that is how the water gets into the gas as well as from condensation forming in the tank which is another reason why to keep gas tanks full. The ethanol pulls the water out of the air in the gas tank and then separates into three levels over time with water on the bottom then ethanol then gas. If you are driving your vehicle enough and filling up often then there usually is not much issue with water in the gas tank.
    Red 94 5 Speed
    1 of 722
    Aug 2007
    110
    6
    My car was converted to e85 in 2009.
    Its been a trailer queen for the past three years.
    It has sat for four to six months with water in the tank issues.
    There should be no issues with condensation with a properly sealed fuel tank.
    May 2018
    1
    Quote Originally Posted by SuperCoupeDave View Post
    thats true... i could not agree more. I tend to use the same method for my business in such cases.
    lasvegastowingservices.com
  1. Proportioning Valve... But is it for an SC???
    By Gregthespy in forum Technical Forum
    Last Post: 09-19-2014, 10:39 AM
  2. Best Remedy For an SC that's a Bit Rusty..
    By PuchRider in forum Technical Forum
    Last Post: 01-16-2013, 11:20 PM
  3. If anybody is looking for an SC
    By Flip in forum Super Coupe Club of Florida
    Last Post: 12-19-2007, 10:17 PM
  4. What is the MAXIMUM amount of boost for an SC block?
    By LXSC in forum Technical Forum
    Last Post: 05-08-2004, 08:20 AM
  5. How bad of an SC addict are you - Serious
    By white91sc in forum Polls Forum
    Last Post: 03-15-2002, 01:47 AM
