Results 1 to 15 of 16
Thread: Removing carbon buildup from pistons, lands, and rings...what's the easiest?
    Jul 2003
    Ottawa, Ohio
    5,399
    I'm in process of refreshing a shortblock and the pistons have a small bit of carbon build up on them. Whats the easiest way to clean them? I've searched and came across a few like, soaking in kerosene, oven cleaner, and wire brush.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Oct 2008
    St Charles(near St Louis)
    431
    what about hot tanking? it shouldn't cost much money to have them boiled. maybe 20 bucks.
    Jul 2003
    Ottawa, Ohio
    5,399
    Ya just thought about that. I have to pick up the block and crank from the shop tomorrow, might just see about dipping them also.
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
    Sep 2003
    P-Town, MN
    2,510
    I'm cleaning piston crowns right now too. I use a brass wire wheel on a cordless drill.
    Oct 2008
    431
    rzimmerl...you are getting set up with an AR correct? what kind of power are you estimating? I'm assuming around 340ish to the wheels, I'm probably way off
    I'm curious as to what kind of fuel system you have to support it though.
    Apr 2005
    Nor Cal
    2,976
    I use a piston ring groove cleaner tool for the ring grooves.
    - Dan
    Jul 2003
    Ottawa, Ohio
    5,399
    Yes, I have an AR. I am hoping for 350+ with the refreshed motor, ported heads, and cam. My member page is up to date so you can see what I will be running.
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
    Illinois
    2,838
    Believe it or not easy off oven cleaner. It comes it a spray.
    Jul 2003
    Ottawa, Ohio
    5,399
    I wish I would have tried the oven cleaner. The shop tanked them and "said" the rings broke when they tried to remove them to clean the ring grooves. Guess its time for new rings now.
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
    Madison, Ohio
    17,549
    I'm wondering what they "tanked" them in because normal hot tank solution is completely incompatible with aluminum. We have a tank with carb solution which works fairly good to soften the carbon but you still have to scrape the grooves with an old broken ring or ring groove cleaning tool to get all the remaining carbon from the root of the grooves. You don't want ANY carbon left in the bottom of the grooves or you may end up with broken rings in the motor.
    If the pistons are truly clean then you have on other issue to be concerned with and that is pin lubrication. The carb solution (or whatever they used to soak them in) will have removed all the oil from the pins and you'll need to work oil into them before re-assembly or you'll stick a pin in short order too.
    I've pulled literally hundreds of rings out of old pistons and never broken one ever so I don't know why they would have broken these. Most likely they just tossed them in a bin while they were removing them and didn't want go looking around for them or else they broke them on purpose. Anyway, doesn't matter at this point.
    Email me here.
    Jul 2003
    Ottawa, Ohio
    5,399
    They didn't use a dip tank, they used one of those heated rotary wash machines. There is still some crap in the oil ring groove even after "they used a ring groove cleaner", they scratched them with something maybe a pick since there is very small shiny grooves. The compression ring grooves look OK, but I'll use a flashlight tonite for a closer inspection. They did soak the pins with oil and the move freely. I am going to inspect them better tonite, and see how the grooves look. Probably still going to have use oven clean and then buy a scraper and redo it myself. This was the last time they will get any work from me.
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
    Mar 2003
    Edmonton, Alberta Canada
    3,004
    The best thing to remove carbon is an industrial paint stripper like TalStrip. It melts the carbon and it just washes away. Just wait for it to "cook" and hose it off with a pressure washer. Just don't get any on your skin.
    Greenville, IN
    4,261
    I don't know how much the ring groove cleaner tool is...but I borrowed one and it made the job a ton easier...I cleaned as best I could dry, then sprayed out the little bit that was left with carb cleaner. I can't imagine how long it would've taken with anything else
    Matt Haub
    Madison, Ohio
    17,549
    The heated pressure washers do not get the carbon off. Easiest thing to clean grooves with is a broken piston ring. It will get right to the bottom of the groove and won't damage the ring land. You'll have to turn it over and go both ways though because it's beveled on one side. Another big help I've found is to soak the whole mess in carb solution for a few days. Of course having a carb solution tank is a big plus. I just did this same job a couple weeks ago and it went pretty slick overall.
    Email me here.
    PNW
    6,376
    Easiest?
    New pistons & rings.
