Results 1 to 11 of 11
Thread: Boost and HP on stock internals?
    Oct 2008
    St Charles(near St Louis)
    431
    I'm sure this has been discussed several times before but my searches turned up nothing . So if you know of a thread that has discussed this already please link to it so I can read thru it there.
    I need to know how strong stock internals really are, how much boost they can handle and what the HP limit is with a fresh but stock motor.
    Also, does anyone know if there are "log-style" manifolds made for these cars that look like this?
    http://www.dragsource.com/logmani.jpg
    or something with the secondary flange at the end of the "log"(facing backwards/forwards instead of down) as opposed as to the middle. I need something that takes up as little room as possible and can hug the engine pretty close.
    Thanks,
    Seth
    Aug 2004
    KSRQ
    5,153
    http://www.sccoa.com/forums/showthre...ighlight=build
    You might find this link of interest. In fact I'm glad I went back and read it again. Some interesting comments and opinions now a year later.
    Ira
    Nov 2002
    Bowmanville, Ontario
    1,949
    That was a nice revisit.......Much of it is beyond my mechanical comprehension. but interesting nonetheless. I appears that. just like most things, a wee bit of moderation and some good common sense can acheive good results.
    Longevity of the stock motors intrigues me. Driving style, as i have seen with the vehicles I drive at work (ambulances) seems to have a great deal to do with it. General maintenance, regular inspection et al.
    Since I have no intention of reaching for these lofty goals re" hp", I expect the motor in my '95 to survive long after I am dead and gone.
    Thanks for the link.
    Matt
    Aug 2006
    Toronto, Canada
    307
    Cool, very impressive numbers. So with a year of driving it racing it (?) under your belt. How did everything hold up? Were there any issues with the bottom end or the balancer at that HP level? It sure seemed to be the focus of discussion in the later part of that thread...
    Dan
    Aug 2004
    KSRQ
    5,153
    Quote Originally Posted by Dangle View Post
    Dan
    Bent a rod after about 1000 miles, but not for any of the reasons being kicking around. It was caused by detonation and it took out the #3 cylinder. The rest of the block was fine for the most part. A knock sensor related problem, it was not something we anticipated.
    The engine has been rebuilt and is making similar power and I believe we have accounted for the knock sensor issue this time.
    Ira
    Aug 2002
    Prior Lake, MN
    1,302
    im running 400rwhp and 500 ft/lbs tq with 18 psi on a stock rebuilt block. no problems yet...
    Dec 2003
    Altoona IA
    3,237
    Quote Originally Posted by aplvlydrtybird View Post
    ^ with a turbo
    350 rwhp and 404 rwtq MPx and 16 psi on a stock rebuild.
    Aug 2002
    Prior Lake, MN
    1,302
    [QUOTE=90blkbrd;791827]^ with a turbo QUOTE]
    Ha true but boost is boost
    May 2007
    Wichita, KS
    3,018
    blkbrd.. its also 30 over with i believe sealed power pistons....
    and its all about tuning... your car is tuned very well... and it runs like a bat out of hell! and still has the factory gear ratio, i might add...
    Dec 2006
    New Jersey
    290
    i've been hitting around 22 pounds of boost on a stock block (not sure about the power). the only work done to it is the arp head studs and new head gaskets.
    Aug 2002
    Prior Lake, MN
    1,302
    Quote Originally Posted by sinhumane View Post
    the pistons are just hyperucrackit pistons nothing special.
    but true, tuning is key on any vehicle.
