Results 1 to 15 of 20
Thread: Window Glue
    Apr 2008
    15
    Window Glue
    The glue or expoxy holding my window clips to the window broke loose. I was wondering what type of glue I am suppose to get and also should I just go ahead and replace those clips. How hard are they to do?
    THanks!
    Jul 2003
    Eastern (nee Western) PA
    4,993
    I have tried many different products, but nothing works as well as the stuff that pro glass shops use. They use fancy 3M two-part epoxies with a special applicator gun and what not. I looked into it, but I found it much better to take it to a body shop and have them do it. I explained what I wanted done, I cleaned the clips and glass, removed the inner door panel, and dropped it off. $40 later, it was perfect, and it has worked for about 2 years.
    Best $40 ever spent.
    God bless!!!
    Former Birds:
    Salem OR
    6,836
    Ford shows TSB 92-11-2 on this issue...
    ISSUE: The front door glass may separate from the glass bracket because of poor adhesive material. A procedure has been developed for refastening the door glass assembly when the bracket separates from the glass. Previously, replacement of the entire glass assembly was required.
    ACTION: Thoroughly clean the glass bracket and reattach it to the glass.
    After removing the glass assembly from the front door:
    1. Mark the glass for the bracket location.
    2. Clean glass.
    3. Remove pink primer from the plastic bracket.
      1. Soak in a tray filled with 3M General Purpose Adhesive Cleaner (3M #08984) for approx. 20 minutes.
      2. Use a wire brush to clean the inside of the 'U' channel plastic bracket.
      3. Clean glass at the bracket location w/same adhesive cleaner, being careful not to remove bracket locating lines.
    4. Mix and apply 3M two-part adhesive system 'Structural Adhesive' (3M #08101) to the inside wall of the 'U' channel bracket.
    Adhesive has a 4 to 5 minute drying time. Cure at room temperature for 4 hours and reinstall assembly into car door. Restrict use of window system for 48 hours for full cure.
    If this sounds a bit too tricky, take it to a shop as suggested above by S_Mazza.
    Oct 2004
    Charlotte, NC
    8,159
    Just go to your local junk yard and remove a window from any bird or cougar (89 - 96)....
    They are not that hard to swap out, if you can find one that is still intact.....
    You might get lucky and find one that has the metal clips on it.....
    May 2004
    187
    I had to re-glue my driver side window about a year ago.
    I went to a nearby automotive glass shop and asked if they would sell me the glue that they used.
    They sold me a tube (as in tube for a caulking gun) of "Sikaflex 220+"
    The tube says :
    Sikaflex 220+
    Cold applied
    Direct Glazing adhesive
    I found this stuff to be difficult to use.
    Instead I just used some Ultra Blue silicone gasket sealer and kept the window closed for about a week before opening.
    It worked great! It is still holding just fine.
    I also cleaned the window real well with alcohol before applying the silicone.
    Greenville, IN
    4,418
    NAPA sells window adhesive for this purpose, I think 3M brand. The kind I bought was a cartridge for a special gun that mixes the two-part epoxy...I didn't buy the gun, but used the cartridge to manually mix the epoxy (like JB weld). It has held up fine for...3 years I think. If I remember right, the epoxy costed me around $12 and should be enough to do 12+ windows. The big think is making sure that the clips and glass are as clean as possible. And I also recommend getting some of the metal clips too (if it's not too much trouble) They're wider just feel better. I did use the plastic clips on the car I fixed around 3 years ago though, so they work fine too.
    I don't think this is the actual type I bought, but it looks a whole-lot like this:
    http://www3.3m.com/catalog/us/en001/...er/output_html
    Matt Haub
    Black '89 5spd - 281K miles, MPx, E85, Alky-Inj ¶ RWHP: ? RWTQ: ? ¶ Best 1/4mi:12.521, MPH:107.23mph
    Norcross, GA
    3,321
    I've had 2 windows come loose from the clips over the years and glued them back into the clips with clear flowable RTV window sealer and it worked beautifully. 5 years later it's still holding.
    Dallas, TX
    5,717
    Quote Originally Posted by sd_iconoclast View Post
    Yup. I use my favorite adhesive, Black RTV silicon. I clean the glass and the clips well with brake cleaner; fill the clip with the RTV, attach and let sit with the window raised for 24hours. Because the window has a shock at the end of travel, a hard set epoxy of any sort (JB weld, epoxy, etc) is a poor choice as it will fracture. A rubber type adhesive will stand up for years.
    Jun 2008
    Muskegon, Michigan
    1,006
    Is it possible to remove a windshield yourself and install it? from a 93 to a 95?
    Oct 2004
    Charlotte, NC
    8,159
    Why not.....
    I took one from a 95 SC and put in into a 90 SC.....
    It's a big ~~~~ unless you have the right tools to remove it.....
    SCCoA Member#1257
    3,321
    2. Clean glass.
    Hey Ken, did you ever try this method? Wondering how it worked out for ya. Getting tired of doing windows pretty much every year! I'd like to find a good propper method that lasts longer. Three out of four SC's in this picture needed window work. I got through 2 cars, one still needs both windows done.
    Salem OR
    6,836
    No, I haven't done this exact process, sorry.
    In the past, tho, I've used 3M yellow death, after wire brushing and blowing clean w/compressed air. Our side glass is fairly large, making it more prone to size changes with temperature, so anything you can do to help the parts stay together is worth the trouble. If you're seeing repeated fails with an otherwise good process, I'd look at anything the might contribute to the issue, such as tight/mis-aligned channels, etc. Any chance there is 200 lb. dog that insists on hanging out a window that isn't open all the way
    Today, I think the glass shop pros have access to much better materials than I ever did.
    Ken
    SCCoA Member#1257
    3,321
    Ken
    Well I didn't do the prep work on the clip as outlined in the TSB, but did clean them up really good. They were already super clean as they are only 54k miles. I ended up using the 3M #08101 structural adhesive on the clips/glass. Man, that stuff starts curing fast! Looks promising. Been a couple days since I did this. I'll probably give them a few more days before I try the windows, just to be sure. However, this 3M stuff looks much stronger than the regular RTV stuff from the parts store.
    Greenville, IN
    4,418
    That's the stuff I used....FWIW...it's still holding fine after 11years.
    Wow..time flies.
    Matt Haub
    SCCoA Member#1257
    3,321
    Wow..time flies.
    Good to know! I let them sit for a week. Driving the car today so I'll give them ago.
  1. Driver's Window Repair and "Born On Date"
    By carlislesc in forum Technical Forum
    Last Post: 07-04-2006, 09:37 PM
  2. MN12 Performance Window Regulator Rebuild Kit
    By Rich Thomson in forum Non Technical Forum
    Last Post: 06-30-2004, 07:33 PM
  3. The Window Fix w/pic's
    By JAFO in forum Technical Forum
    Last Post: 07-06-2003, 11:45 PM
  4. window glue???
    By HappyHourHero in forum Technical Forum
    Last Post: 02-25-2003, 11:33 AM
