Results 1 to 10 of 10
Thread: GTP rotor pak.....SOLD
    May 2004
    Va. Beach,Va.
    7,145
    I have a GTP rotor pak that I bought for my MPX case before the problem came to light about coating coming off from ODing the blower. I installed in the MPX case but never ran them, took them out and installed a set of uncoated rotors. They're ready to install with the line up dowel in the correct position. A couple of places at the ends of the rotors have a very little chipping of the teflon but overall they're in really good shape, all they are to me are a paper weight in a box in the garage.
    $100 plus shipping
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    Madison, Ohio
    17,683
    How much clearance is there between the rotors and the plate? How about perceptible gear lash?
    Email me here.
    May 2004
    Va. Beach,Va.
    7,145
    Dave, I'm just a shade tree mechanic so how do I measure what your asking? I guess I could use a feeler gauge to measure the clearance between the rotors and plate but how do i measure the gear lash?
    SCCOA Member #2406
    Jul 2003
    Russia, Moscow
    115
    Its coated roror pack?
    I take if coated.
    Also i need snout.
    LMK.
    Thank you.
    May 2004
    Va. Beach,Va.
    7,145
    Quote Originally Posted by Flint View Post
    I take if coated.
    Also i need snout.
    LMK.
    Thank you.
    You have a PM.
    I have a snout that needs a seal if you're interested.
    SCCOA Member #2406
    Madison, Ohio
    17,683
    Quote Originally Posted by nickleman60 View Post
    To measure rotor clearance you need to install the rotors into a case just far enough that the alignment dowels start to engage, then stick a feeler gauge in there and check clearance. This is a procedure that all people with overdriven blowers should know how to do because it was through *assuming* that I was ok that we lost 2 blowers in one day. It's easy to do and it could really save your butt one day.
    As for gear lash, while you have the rotor pack in there just rattle the gears back and forth. If you can feel (and hear) the gears clicking back and forth then they are worn. It seems like the GTP's had problems with this. I have a set of rotors in my one car that look perfect but they have so much gear lash that the doggone thing sounds like a cement mixer.
    Email me here.
    May 2004
    Bmore
    3,228
    $100 plus shipping
    Would you happen to have the GTP snout? Let me know.
    Jan 2003
    Allentown, Pa
    1,031
    Quote Originally Posted by Dahoopd View Post
    I"m pretty sure the GTP snouts are part of the actual case, but I could be wrong.
    Madison, Ohio
    17,683
    Quote Originally Posted by getblown View Post
    No, they can't be because as the picture shows, they are removable. Perhaps you are thinking about the inlet being part of the case.
    Email me here.
    Jan 2003
    Allentown, Pa
    1,031
    Very true. I stand corrected (and smacked for being dumb).
  1. Supercoupe 3 ----- x5, z28, gtp 0.
    By CanadianCoupe91 in forum Technical Forum
    Last Post: 08-03-2007, 10:42 PM
  2. October SC vs GTP Club Clash 2005
    By Mike8675309 in forum Racing/Track Results
    Last Post: 10-18-2005, 09:34 AM
  3. Former GTP owner interested in Tbird SC's!!
    By Ultra Magnus in forum Technical Forum
    Last Post: 06-21-2005, 01:12 AM
  4. Gtp
    By SC UL8R1990 in forum Racing/Track Results
    Last Post: 01-17-2005, 02:37 PM
  5. GTP vs SC
    By noV8required in forum Racing/Track Results
    Last Post: 12-10-2003, 12:35 AM
