Results 1 to 15 of 17
Thread: Remflex Exhaust Gaskets
    Forked River, NJ
    2,092
    I've been searching for perfomance exhaust gaskets for a while. I thought I had found a set made by Percy's, and special ordered them through Summit, but when I got them, the ports were waaaaay too small.
    But I just stumbled upon these from Remflex, and ordered up a set.
    http://catalog.remflex.com/FORD_Head...t_p/rf3044.htm
    I'll let everyone know what I think when I get them.
    Madison, Ohio
    17,665
    They should work great. Solid graphite on a steel core is a proven combination, in fact it is exactly what the Felpro 96-98 Mustang gaskets are made from. The Felpro's are a little thin so they won't take up as much of an imperfection as these will though. When I've had warped flanges I use 2 sets of the Felpro together to double both the crush and strength of the gasket (kind of like an MLS gasket for the exhaust).
    And if you are careful they are totally re-usable.
    Email me here.
    2,998
    I have had these on my car for quite a while with the first generation Hull long tube headers that were not the best fit:
    94-99 Mustang 3.8L exhaust manifold gasket (Fel-Pro MS 95528, replaces Ford F5SZ-9448-C), coated steel, use copper gasket sealant.
    These might be the same ones David had mentioned.
    I also recommend the Stage 8 fasteners on the exhaust, but I believe Doug already uses those. They come in bolts and studs and will NOT back out.
    Forked River, NJ
    2,092
    Quote Originally Posted by gldiii View Post
    George,
    I've been using the late version Fel-Pro 95528's, but I need something that will do a better job of sealing, I'm hoping these thicker gaskets will do the trick.
    And I'm going to try some stainless steel Percy's split lock header bolts this time.
    http://www.jegs.com/i/Percy%26%23039...21008/10002/-1
    Regards,
    Sep 2003
    P-Town, MN
    2,511
    Quote Originally Posted by DLF View Post
    Looks nice. Do you know if the price reflects both or just one gasket? The site says '2/set' which can be interpreted a couple different ways.
    It's only impossible until we do it.
    22-year SC owner - '93 SC AOD (non-locking TC). Same car, same original paint!
    Current setup: 12.550 @ 111.09, 1.917 60ft, no bottle.
    Forked River, NJ
    2,092
    I believe its for the pair, but we'll see what I receive....
    Forked River, NJ
    2,092
    Got 'Em
    Received a pair. Port size is right. About 4mm thick, so they'll be about 2mm when installed.
    Sep 2003
    P-Town, MN
    2,511
    George,
    Summit shows them as polished and $11 cheaper.
    http://store.summitracing.com/partde...8&autoview=sku
    Forked River, NJ
    2,092
    Quote Originally Posted by pablon2 View Post
    Same item, better price.
    Thanks!
    May 2003
    Baton Rouge, LA
    175
    Did you get these installed? How did they work. I've currently got a warped exhaust manifold and I'm looking at trying these. It's already blown through the standard exhaust manifold gasket that was in the gasket kit when head gaskets were replaced.
    Forked River, NJ
    2,092
    Quote Originally Posted by kendall221 View Post
    Not yet, but I'm sure they'll do the trick. Got another one of my cars on the lift at the moment.
    May 2003
    Baton Rouge, LA
    175
    I've ordered a set of the RemFlex gaskets. Should be here next week. 10x cheaper than replacing a manifold. Will post again once they're installed.
    '95 SC
    Sep 2003
    P-Town, MN
    2,511
    I ordered a set yesterday morning as well. $42.59 shipped.
    May 2003
    Baton Rouge, LA
    175
    '95 SC
    I just received the gaskets. Here's how they look against the stock manifold (94 - 95). Gaskets are round where manifolds are actually flattened along bottom. Hopefully they still seal.
    The second pic shows where I marked the gasket openings on the flanges.
    Update:
    Mechanics decided not to use these gaskets due to fact that I found a new exhaust manifold, and therefore not working with a warped one. Also, they were not that impressed with the gaskets since they aren't that great of a fit to the manifold and the graphite was starting to flake off while being handled. So, used the Fel-Pro exhaust manifold gaskets instead.
    Sep 2003
    P-Town, MN
    2,511
    I installed the gaskets lastnight. I didn't see the 50% crush that they claimed, but they look like they'll work nicely with the Kooks shortys. I checked the coverage of the gasket to the primaries before installing (neglected to shoot a pic) and they matched nearly perfectly. I agree they are very fragile and would be easy to crack them.
  1. need help on m112 blower
    By hinterland in forum Technical Forum
    Last Post: 03-12-2008, 11:18 PM
  2. cilinder head airflow intake vs exhaust questions
    By blown96bird in forum Technical Forum
    Last Post: 03-28-2006, 02:14 PM
  3. Replies: 3
    Last Post: 09-03-2005, 09:43 PM
  4. Exhaust Experts
    By rickbtbird in forum Technical Forum
    Last Post: 08-21-2005, 10:18 PM
