ricardoa1
More questions Ricardo:
For the aftermarket IC, is the owner of the vehicle ready to compromise comfort for performance?
Problem #1:
Theoretically, 33% of the condenser's efficiency will be lost with this configuration. A third row may solve this problem.
Problem# 2
Mounting....
If you look at the AIR CON A/C condensers Its missing about 33% of it already. George D bought a 3 core version and that worked very well for his car and as others have. If the company does not see a 2 row 1/4 suitable like they originally stated then 3 row versions would have to be the upgrade.
But i think that the 2 row should prove to be enough for some.
My car overheats with the stock condenser and the A/C on, as so many MP FMIC owners. So to me a car that doesnt overheat is more important then an AC system that operates at 67% percent.
As for brackets those can be made by us, by bendin a piece of metal and a couple of screws. But Ideally if they take a stocker and remove 1/3 of the fins and tubes on the bottom of it would be even better. that way the two lateral supports that the tubes mount to would reach to the bottom of the frame of the car and lift the whole assymbly to the correct position.
