I'll take one how do I get this going , this bolts right up with no problems ,right?
We're talking Supercoupe's here.... nothing bolts on without issues .
Fraser
Does anyone know if the 3 core design will fit with the Aluminum radiator from Raceware? will there be any problems mounting them since not stock radiator?
called him yesterday and that was a question he asked.
the way a radiator mounts shouldn't be a problem. The condenser sits in an area that the radiator doesn't fit, since the top tank of the radiator prevents the radiator from moving very far forward.
i just don't know how it will fit down there. Pertaining more to installing the condenser with the radiator already in there. I guess he was asking if the different size of the condenser will get in the way of the radiator. Will there be any kind of issues with that different radiator or will the condenser fit next to either radiator the same?
As Mike pointed out, it fits in the stock location as your existing condenser so no mounting issues there. If you still have your stock condenser in the car, take a look at it and where it is and that's where the new one will reside also. If you are wondering how it will look, go to the 1st post and look at the pictures and then look at your stock condenser again and you can see what is being changed depending on which condenser you are ordering.
Oh, I should have pictures of the new ones in a couple of days.
Duane, are those part numbers listed in that first post the actual numbers for the three options he is willing to make? I know there was some question what he was willing to make and what each part number was for.
Ira
Ira
The first one AIRCON 2row is the same,
The 3 row Aircon style he added a "P" to the end of the part #s,
I believe so.
I don't think that is quite correct. I believe the one he is making for me with the Parallel Flow core will have the "P" on the end of the 3-row part number.
As far as I know, I have the correct part numbers in the first post. Two pictures have been added to the first post to show the actual units.
Ok I thought you said that he added the the P to the three row yesterday in PM.
Did he give you the number for the MP 2row 9in version?
He did add the "P" but I'm thinking that's for the Parallel flow that he is building for me.
The one that is pictured for the MP is 8.75 X 27.5
Whats the part # for that? I assume that is mine
Parallel flow??? Tell me more about that.
Ira
Any idea what the pressure drop is across each option? I'm sure the 2 row has the least pressure drop of the 3.
