Results 1 to 11 of 11
Thread: Engine Makeover
    Jun 2008
    Muskegon, Michigan
    1,006
    Lightbulb Engine Makeover
    OK, getting ready to put the engine back together this is my list of parts, anything else?
    Oil pump kit melling k-137 $23.99
    Headbolts felpro es72131 $15.99 x2
    Head gasket Set felpro hs9642pt $85.99
    Rear main seal Felpro b540644 $24.99
    Motor mounts Duralast a2661hy $36.00 x2
    Oil pan gasket OS30625R $8.99
    Engine oil What should I use? 90,00 on engine
    Oil Filter Bosch 3422 $6.99
    Tranny Fluid what should I use? Ford rebuilt Trans
    Antifreeze
    Sealer Copper?
    Getting everything from autozone.
    Thanks,
    Jerry
    May 2003
    Omaha, Nebraska
    6,253
    Quote Originally Posted by Cherry93SC View Post
    Antifreeze
    Sealer Copper?
    Thanks,
    Jerry
    I would use studs for the heads rather than bolts. Thats really important. I would look into solid rubber engine mounts as well.
    Ken
    Jun 2008
    Muskegon, Michigan
    1,006
    What is the difference I guess I never caught on to the studs I figured studs are bolts :|
    May 2004
    Va. Beach,Va.
    7,155
    I would suggest getting the high volume oil pump that came in 94/95 SC's, Melling M-246. If you gonna change it might as well upgrade.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    May 2004
    Va. Beach,Va.
    7,155
    Studs are re-usable, head bolts aren't. Buy the ARP head studs for a 2.8 chevy. They're the same as the ones for a supercoupe but cheaper.
    SCCOA Member #2406
    Dec 2002
    Wintersville, OH
    4,109
    I see an oil pan gasket listed there. Is there one on the later sc's because I know mine was just rtv from the factory. I didnt think there was one for our cars
    Jun 2008
    Muskegon, Michigan
    1,006
    The oil pan gasket is not really much of a gasket, http://www.autozone.com/R,2570352/ve...ductDetail.htm
    Where can I get the Studs from? Does Autozone carry them?
    Will the Melling M-246 fix right?
    Thanks
    May 2003
    Omaha, Nebraska
    6,253
    Thanks
    Most get them from Summit. The head bolts have to be torqued and done right in a certain procedure. I guess its a pain in the butt. The head studs can be reused and also they can be torqued higher than the bolts for more clamping force. They are really worth it in my opinion.
    Ken
    21,150
    Thanks
    Yes the Melling pump #M246 is a direct replacement.
    Pump and studs can both be purchased on line from summit.
    Jan 2007
    Miamisburg, Ohio
    355
    Thanks
    I got my head studs from summit, they were the ones for the chevy 2.8l. Here is a link to the ones that I got http://store.summitracing.com/partde...3&autoview=sku. I went back and retorqued them probably 3 times just to make sure they held the torque. And so far they are working really well for me. For the motor mounts i would get some solid rubber mounts from victor http://spinningwheels-sc.com/index.a...PROD&ProdID=18 . And once you get it back together make sure you prime the oil system before you try to start it.
    May 2004
    Va. Beach,Va.
    7,155
    Thanks
    Autozone carries the Melling M-246 pump, I bought mine from there.
    SCCOA Member #2406
  1. Engine gave up..
    By Jogi in forum Technical Forum
    Last Post: 09-29-2008, 07:28 AM
  2. Replies: 5
    Last Post: 06-23-2008, 02:19 PM
  3. Engine Swap Complete but a few problems
    By 85TbirdSC in forum Technical Forum
    Last Post: 12-17-2003, 01:06 PM
  4. Engine Swap Questions
    Last Post: 12-03-2003, 07:39 AM
  5. Engine Upgrade
    By Goatroper in forum Technical Forum
    Last Post: 08-27-2002, 12:52 PM
