After replacing the cam sensor this morning the car starts and runs much better. Took it for a 12 mile drive to test some tunes, and other than getting some CELs and running a little warmer than usual, everythings seems to be fine.
Decided to see how much boost it's making with the larger motor and it's making a max of 17 pounds which is pretty close to what I was hoping for. At the same drive ratio I made 20 pounds with the old motor, so the 3.00" diameter pulley I've got should put it back to about 20 pounds. Currently using a 3.25" dia pulley.
It feels strong, just not quite as strong as my old motor did, but the timing is set a lot lower and I don't have any idea what the A/F ratio is it WOT. I'm sure it's going to be fine once we get it tuned and increase the boost a little. For now I'll just be driving it around to put some miles on the motor.
