Results 1 to 7 of 7
Thread: Have to jump fuel pump relay for engine to run
    Norcross, GA
    3,314
    I've been working on my 89 trying to get it going after sitting for 5 years. If I shoot some starting fluid into the MAF it'll crank up and idle but if I give it any throttle it stalls right out. If I jumper the fuel pump relay at the EEC test connector the pump runs and I can rev the engine but only if it's jumpered. No jumper and it stalls with throttle. Pulling the fuel pump relay kills kills the fuel pump so I know the relay is good. It looks like the fuel pump relay coil connection goes to the EEC pin 22 from the test connector. Could the EEC have failed? Anybody seen this before?
    PNW
    6,586
    Checked the impact sensor...trunk left?
    Norcross, GA
    3,314
    Yes, that's in series with the fuel pump relay coil so if the relay operates and the pump can be jumpered to run it's got to be. I tripped it and reset it just to be sure.
    PNW
    6,586
    Any chance the car was equipped with a security system & drive-away cut-off?
    Norcross, GA
    3,314
    It does have a security system but it was never a problem in the past when I had it running. Is there a switch somewhere that needs to be reset, maybe?
    Orem, UT
    5,902
    At least yours starts. I had to hotwire and switch my fuel pump and then come to find out I have no spark. I put in a new ignition switch, new (used) IRCM and computer, and still nothing.
    Scott Long
    1992 SC 5-speed
    PNW
    6,586
    May be time to do the basics...
  1. I found this FAQ on the SC
  2. can you run a standard fuel pump with 42lb injectors
    By mybirdcanfly in forum Technical Forum
    Last Post: 03-03-2008, 09:42 PM
  3. Continued ABS woes (and others)
  4. Bad Relay Causes Low Fuel Pressure...
    Last Post: 11-12-2006, 01:05 PM
  5. Fuel pump relay
    By buggybugster in forum Technical Forum
    Last Post: 11-02-2004, 05:47 PM
