View Poll Results: How have you set your TV cable?
Voters
15. You may not vote on this poll
  • Set it as tight as I can set it
    5 33.33%
  • Set it according to the book
    7 46.67%
  • Never have touched it
    3 20.00%
  • Whats a TV cable
    0 0%
Results 1 to 12 of 12
Thread: How has everyone set their TV cable?
    May 2003
    Omaha, Nebraska
    6,207
    You guys like Ricardo and Ira can just sit this poll out Just curious how everyone has set their TV cable on their AOD. I have been told to just set it out to the maximum travel. The thread on the TCCoA has it 5/16 inch back on the square shaft from the maximum travel. Whats the consensus
    Ken
    Boston, MA
    7,356
    For digital I use an HDMI cable
    For analog I use a coaxial cable.
    May 2003
    Omaha, Nebraska
    6,207
    Is it the water you drink out there?
    Ken
    Dallas, TX
    5,696
    Quote Originally Posted by kenewagner View Post
    Ken
    TV cable... get it?
    You need a 3rd option.. according to the book, and then 1 notch at a time until satisified.
    May 2003
    Omaha, Nebraska
    6,207
    TV cable... get it?
    You need a 3rd option.. 1 notch at a time until satisified which is how I adjust mine.
    We dont get TV in Nebraska yet, still listing to the radio
    What determined your satisfaction and where did you start, at the min or the max setting?
    Ken
    Jul 2003
    Eastern (nee Western) PA
    4,993
    TV cable... get it?
    My method was something like that.
    I asked the transmission shop to check it. It came back from them upshifting way too early and flaring RPMs on acceleration downshifts. So I cranked it up a little, till I thought it was working right. Not the best method, but well, the transmission was a $200 used model.
    God bless!!!
    Former Birds:
    Jun 2008
    Muskegon, Michigan
    1,006
    Tight as possible gives it the right shifting points, If it's to lose it feels like it shifts to early.
    I hate when I drive to the corner and it shifts just as i need to hit the breaks and slow down grr.
    Jerry
    Sep 2003
    P-Town, MN
    2,511
    Gauge on the TV port and use Rotunda tool at the adjuster block. Set it at about 30-34psi with tool installed. Should drop to zero with tool removed.
    It's only impossible until we do it.
    22-year SC owner - '93 SC AOD (non-locking TC). Same car, same original paint!
    Current setup: 12.550 @ 111.09, 1.917 60ft, no bottle.
    Dallas, TX
    5,696
    Basically whichever notch which lines up with the unloaded tension in the cable. That would be the min setting. Drive it around and if I feel like it takes too much throttle to get it to down shift, I tighten it up (more tension) by about 2 notches. Drive around for a day or 2. If it then feels too quick to downshift or its too harsh on the upshift, I loosen it by a notch or 2.
    Dallas, TX
    5,696
    Quote Originally Posted by pablon2 View Post
    Thats consistent with what I do but without the guage... the rotunda tool pulls the cable tighter by a fixed amount and when removed allows the TV valve to go to its outer stop position.. (hence no tension in the cable).
    Oct 2004
    Charlotte, NC
    8,159
    I set mine up with no slack in the cable.....
    Drive it around, then adjust it a little tighter (2 clicks).....
    Repeat until I am satisfied......
    Greenville, IN
    4,329
    Quote Originally Posted by the-big-e View Post
    Me too...cept in one-click increments.
    Matt Haub
  1. Custom 8 and 8 rib crank pulley and 3 piece billet set....
    By BT Motorsports in forum Group Purchases / Specials
    Last Post: 07-11-2004, 07:52 PM
  2. I have an AFPR....what to set it at??
    Last Post: 07-29-2003, 11:13 PM
  3. Will i have a prob. with this throttle cable??
    Last Post: 07-08-2003, 07:01 PM
  4. Parking Brake Cable route on SC?
    By GreenBirdLX in forum Technical Forum
    Last Post: 04-18-2003, 12:47 AM
