Results 1 to 13 of 13
Thread: runs but lost boost
    runs but lost boost
    Went on a road trip to Cleveland from Pittsburgh. Ran perfect on the way there. Car has 112k miles. On the trip back it rained like cats and dogs. Early in the trip the car lost all boost. Pulling out from a toll booth, it would just creep until it got up to speed. Every time I gave it hard gas it just bogged until I got off of it. The car did 70 most of the way home, there was just no boost. It starts, but there is still no boost. I took the air silencer off, have never replaced the cam sensor, crank sensor, or the DIS. Took it to a good mechanic, he thinks it's the computer or the MAF. He's looking for used parts.
    I kind of gave the car to my 20 Y.O. son. He loves the Tbird, I do too, but don't want to spend a fortune (4 kids, bad economy . . . )
    Please -> any ideas ?
    Thanks and a thousand blessings for your help.
    Ron
    Latrobe, PA
    Jun 2008
    Muskegon, Michigan
    1,006
    Whats the boost gauge read at idle? Could be a vac. leak its pretty common.
    Jerry
    May 2003
    Omaha, Nebraska
    6,253
    By Pass stuck open would be my first guess. Second would something sheared in the front head of the supercharger keeping the rotors from spinning
    Ken
    Mar 2007
    Central Kentucky
    767
    I'm with Ken---Dan
    I don't think I have ever owned a car that was finished---unless it was totaled.
    Jul 2003
    Eastern (nee Western) PA
    4,993
    I agree, it sounds like a supercharger or bypass problem to me.
    There's nothing electrical about the supercharger, so an electrical problem would not be able to take out your boost. Unless it just prevented the engine from pulling hard enough to drive the supercharger and create boost, but you didn't say it was running badly. So I am thinking it is a problem in the supercharger or the bypass.
    I wouldn't worry too much - although it sounds intimidating, it is not too hard to remove & replace the supercharger. And if you know where to look, repair services are not very expensive.
    God bless!!!
    Former Birds:
    Orem, UT
    5,902
    What about plugs/wires. He said it bogs if you give it too much gas. Could the bogging be bucking?
    I'd look at the belt for the jackshaft, the belt for te SC, the bypass valve on the back on the supercharger, and then maybe take the supercharger off (takes about 25 minutes) and spin it by hand and see if the rotors turn. If they turn freely, then the supercharger isn't the problem.
    boost is back ??? !!!
    Thanks for the input all - Blessings.
    Picked it up from the garage. The mechanic still says MAF or computer, and that these
    are a pain. $45 for him to look. At idle it has, what, -15 (about 9 clock on the dial)
    Noticed that it didn't mind hitting zero vacuum. Took it for a 5 mile ride, it was like nothing was ever wrong. 10-12 pounds of boost, pulled strong - just like before ???
    Still doing the “hard to start, need a cam sensor thing”, and that’s on the list.
    Have spark plugs and wires, but I’m intimidated ever time I lift the hood. Have a quart of Exxon turbo/supercharger oil from the airport, $15.00 - that I’m going to figure out out to remove and replace our sc’s oil.
    Could a soaked air filter have done something ? Reduce the air flow and freaked out the MAF or something ? It pulled MAF codes the mechanic said.
    I love this car. It was a cool wet morning, the tank was half full of hi-test, and it ran like a big block Ford from my younger years . . . Wow this thing P U L L S . . . just like a 390.
    Again, thanks for the input all, blessings on you, and now on to some R & D for the T-Bird. Attached a few after body work photo's. It's the T-Bird with the christmas tree on it from last year.
    Ron
    Latrobe, PA
    Oct 2006
    va beach,va
    2,585
    Needs a Maf sensor or a fuel pump. Problem is either fuel supply or fuel control. Im sure your mechanic checked fuel supply(Pressure). That would have left fuel control (MAF)...Buy a MAF sensor...They will come and go like that. All it is, is a frequency meter. It has nothing to do with mechanical boost. It has to do with the engines lack of ability to produce enough power to create the boost. Due to lack of fuel...This is a common problem. I have seen it many times. On all makes, not just Ford's
    Apr 2006
    Flagstaff Arizona, 7000ft high, woohoo!
    101
    Smile
    My first thought when you said "ran great, then on the way back it rained like cats and dogs"was that the belt was wet. Maybe it had some gunk built up on it, and the water made it like ice. On my Buick GN when I would go through a puddle I would loose brakes and steering at the same time. Not until I steam cleaned the engine, and put a nice clean belt on the power steering/brake boost pump was it safe to drive in the rain. You could try wetting the belt to see if the problem returns. Danny
    Jul 2003
    4,993
    Quote Originally Posted by frdlvr30 View Post
    That's a good thought. I would suggest checking that out with a scanner or emissions dyno before replacing parts. If the fuel-air mixture seems right, then the problem is somewhere else.
    Maybe a failed harmonic balancer has the timing off?
    God bless!!!
    Former Birds:
    Orem, UT
    5,902
    Been there, but it cracked the balancer all the way around and it slipped timing so bad eventually it wouldn't even run.
    Matter of fact, one of my SC's is like that right now, so I need to get a BHJ when I rebuild that shortblock thats in it. My other 90 SC has a BHJ balancer because the stock one broke. I had to drill into broken pieces to remove it, talk about a pain in the ~~~.
    Thanks all
    Thanks all, many blessings for your input.
    It's running OK now - 2 weeks after.
    Running OK as it was -> I need to do a cam sensor and plugs and wires.
    Any thoughts on the soaked air filter ?
    What could case it to be bad for a few days then go back to how it was ?
    Oct 2006
    va beach,va
    2,585
    Quote Originally Posted by [email protected] View Post
    Soaked airfilter can also cause Maf problems. Especially an oiled K&N filter. You better put a MAF on it. It will be back. Did you not read my previous post?
  1. Boost leaks, what they do and how to deal with it
    By Vernon in forum Technical Forum
    Last Post: 04-16-2013, 12:19 AM
  2. Engine runs great...then bogs under boost.
    By torino1973 in forum Technical Forum
    Last Post: 10-16-2007, 09:02 AM
  3. lost boost
    By ThePikey in forum Technical Forum
    Last Post: 06-28-2004, 01:29 PM
  4. Compression vs. Boost (this should be a FAQ)
    Last Post: 03-05-2003, 01:24 PM
  5. Replies: 0
    Last Post: 03-05-2003, 04:03 AM
