Results 1 to 8 of 8
Thread: Supercharger: Disassembly and Assembly
    Jul 2007
    Memphis area
    411
    The snout seal on my SC was leaking and I did not have a replacement. I did, however, have a SC with a good seal in it but it had some noise in it. I swapped the snouts and now mine has the same rattle. Is is possible I put it together wrong. Is there a right and wrong was to put the snout back on?
    Thanks, in advance for all the help!
    Raymond
    Oct 2004
    Metro Denver Area
    2,514
    May 2004
    Va. Beach,Va.
    7,133
    Quote Originally Posted by Raymondo View Post
    Raymond
    I don't understand why you would put on a different snout that was making noise and now wonder why it's making noise on your sc? Snout seals are very easy to replace.
    Here's the one I bought:
    http://cgi.ebay.com/ebaymotors/ws/eB...2BSI%26otn%3D4
    He sells some teflon gaskets also:
    http://stores.shop.ebay.com/Baileys-...34Q2ec0Q2em322
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    Jul 2007
    Memphis area
    411
    Well because I did not know it was in the snout; I thought the noise was in the SC itself. I have ordered another seal from the same guy you referred.
    My question concerns putting the snout back on. Can it be misaligned?
    Thanks!
    Raymond
    May 2004
    Va. Beach,Va.
    7,133
    Thanks!
    Raymond
    Not that I know of, it has 2 line up dowels on opposite ends that keep everything in line. Unless something was messed up with them it should be aligned just fine.
    SCCOA Member #2406
    Jan 2009
    south florida
    399
    its most likely the snout coupler. its a cheap easy fix. if your supercharger sounds like it has rocks rolling around inside of it, you need to replace the coupler.
    May 2004
    Va. Beach,Va.
    7,133
    Quote Originally Posted by scxr7 View Post
    If it sounds like rocks it's the bearings.
    SCCOA Member #2406
    Feb 2009
    31
    x2 if it sounds like rocks its the bearings.....
  1. M5R2 Disassembly and Assembly
    By ricardoa1 in forum Technical Forum
    Last Post: 02-16-2009, 10:35 PM
