Tony8470
I just got everything put together and I hammered on it to expose any weaknesses on the motor and I definitely found one!
The mods I put on were MP FMIC and SCI underdrives. When I got home there was coolant all over the engine bay! I popped open the radiator cap and there was a steady stream of coolant leaking from the bottom of the crank pulley. I read there is a possible failure of the timing chain cover and the harmonic balancer has a coolant seal. Anyone have the same problem so I can get started on which one?
