View Poll Results: Best solution for intercooler
Voters
122. You may not vote on this poll
  • Double intercooler
    44 36.07%
  • MP FMIC
    13 10.66%
  • Custom FMIC
    56 45.90%
  • Stick with stock
    9 7.38%
Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
Thread: Intercooler
  1. #31
    CA
    1,679
    Quote Originally Posted by XxSlowpokexX View Post
    superslowpoke
    Better late then never
  2. #32
    Apr 2007
    New Orleans, LA
    1,959
    the best intercooler is none, intercoolers retain heat
    bypass the intercooler and spray meth on it, that will solve all your issues its cheaper more reliable less restrictive and enables you to make more powah!!!
  3. #33
    Oct 2013
    Da Cliff (Dallas), TX
    11
    Thumbs up
    Quote Originally Posted by decipha View Post
    I did some research and that is what I'm going to do. I bought an Aqua Mist kit with a low fluid level sensor.
  4. #34
    Orem, UT
    5,899
    Decipha was talking about this for years. I saw one car that had a pipe made to connect the outlet of the supercharger to the return plenum on the intake. It ran like ~~~~. Way to hot of an air charge temp, timing couldn't be retarded enough to make it run good, car felt like a turd, and it popped the headgaskets. You'd have to constatntly spray the meth. Unless you want to tow a water tank behind you to hold your meth mixture, its just a stupid idea. For a car that runs race fuel and only runs for a 1/4 mile at a time, MAYBE you could make it work but for a street car, air to air intercooling is where its at.
  5. #35
    Greenville, IN
    4,426
    Quote Originally Posted by 64.5 Stang View Post
    Build an intercooler and use the aquamist on top of that, when needed.
    Assuming a street car, you'll have a recurring cost running meth all the time, which will make it expensive in the long run. Air is free!
    Not to mention, an IC is "more reliable", since it does not depend on lines, a pump, nozzles, controller, wiring to all be in working order to bring your intake temps down (and therefore help inhibit detonation).
    I love my Alky injection system, but I think it would be a poor decision to run it alone on a forced-induction, performance oriented street car. I had toyed with the idea not long ago, but after thinking about it..nah.
    Matt Haub
  6. #36
    Greenville, IN
    4,426
    Btw, I you're wanting to do this anyway, I would at least get a flow meter and tie it into whatever engine management system you have...if we're talking about an SC, use the SPOUT plug. Pull 8 degrees of timing, should the system fail.
    Matt Haub
  1. Guaging interest in a stock location Liquid Intercooler kit
    By Conan56 in forum New Products and Services
    Last Post: 06-06-2005, 05:52 PM
  2. intercooler leak
    By 90blkbrd in forum Technical Forum
    Last Post: 08-01-2004, 06:48 PM
  3. Double Intercooler vs. Front Mount
    Last Post: 10-19-2002, 03:43 PM
