Results 1 to 8 of 8
Thread: Warning Chime Module
    May 2008
    Tullahoma,Tennessee
    128
    As mine seems to work but only faintly, I am looking for a good module that rings properly. If you have one, give a price and include shipping to 37388.
    Thanks, Chuck
    Oct 2004
    Charlotte, NC
    8,159
    I have a 90 SC that I am currently parting out.....
    Where is the chime module located and is there any way of bench testing it, as the car has been heavily parted out.....
    May 2008
    Tullahoma,Tennessee
    128
    It is located behind the glove box . Its a black module with a white connector with 7 wires on mine. I am not sure of a way to bench test one. I have spent 2 hours just trying to get mine to work and it will get a little louder but only if I put some pressure on the box but I am not sure of how to fix it. I just wanted to have the chime working as my daughter has already left the lights on without realizing it and drained the battery . The key in the ignition chime doesnt work at all as I need the switch connector at the Key cylinder I just discovered mine was broken. I think someone has sabotaged this one to get it so it doesnt work
    Oct 2004
    Charlotte, NC
    8,159
    I might be able to check it with one of my other SCs that I am working on right now.....
    May 2009
    Brantford Ontario CA
    219
    you want a replacement for that annoying little thing??...
    May 2008
    Tullahoma,Tennessee
    128
    lol yes I will feel better knowing that the chime does warn us (me or my Daughter) if the lights are still on I am older now and forget sometimes too lol. Its bad when you go out to start the car and it doesnt do anything and your cables are elsewhere
    Southern California
    303
    Chuck
    What year is your car.
    I was able to fix the one in my 90. If I remember right there are a couple kinds out there. I spent about an hour trying to come up with way to bench test and never did find a way. The 90 has the older style - I might be able to give you a couple ideas. I should still have some pics.
    dbd
    To ALL my fellow Veterans........Thanks!!! U.S. Navy (Corpsman) 1967 - 1971.
    1990 SC
    1997 Mark VIII LSC
    1998 F150 Lariat
    Oct 2004
    Charlotte, NC
    8,159
    What is the part number on yours.....
    I tested three of them on my 92 and found two of them to be faint and the other was very loud.....
    However, none of them worked when the lights were left on....
    Am I missing something here......
  1. Warning Chime Module
    By txsc in forum Want to Buy
    Last Post: 01-23-2008, 09:49 PM
  2. resetting keyless door pad?
    By obucina in forum Technical Forum
    Last Post: 08-31-2006, 03:00 PM
