Results 1 to 13 of 13
Thread: Horsepower
    Sep 2002
    florida
    17
    Horsepower
    I have a 1990 5 speed, I Have done the exhaust, (2". 50 no cats into 3" back to 2". 50) removed the silencer and put in a K&N flat filter. Could someone tell me what the horsepower was stock and approximately it is now?
    I will be putting on a 10% pulley. How much will that add?
    Thank You,
    Scott
    Sep 2002
    Montreal, Quebec, Canada
    3
    The performance you get from your mods is slightly different from an SC to another, depending of some factors.. The most effective way to know your horsepower and torque is for sure the Dyno test... (available in many performance shops)
    Sep 2002
    florida
    17
    Do you know what the horsepower was out of the factory?
    Austin, Texas
    816
    i do!
    Stock horsepower for 89-93 SC's was 210hp with 315lb of torque. the 94-95 SC's stock have 230 hp and 330lbs of torque-- Exhaust can usually add from 7 to 20 hp i believe, but like tslasher said, it just varies on the car. K&N filter i hear adds about 5 so i would think though that you are pushing maybe around 225+ but again like tslasher said, better to go to the performance shop to see...
    good luck-
    Damon
    Straffordville, Ontario, Canada
    357
    Stock:
    8.2:1 Compression Ratio
    210 bhp at 4000RPM
    315 ft-lb Torque at 2600 RPM
    Underdrive kit and chip boost HP to 255.
    Austin, Texas
    816
    OH
    oh, and a 10% pulley is known to add about 3 PSI but its not recommended on SC's with high mileage as it greatly increases chances of those head gaskets going byebye-- it also reduces the life of your supercharger-
    Damon
    Sep 2002
    florida
    17
    Thanks for the information. My car just turned over 80,000 miles and was a one owner car, I donít burn any oil and the car seems extremely tight. Would you consider 80,000 miles too high to go with a 10% pulley?
    Scott
    Illinois
    1,744
    These cars have a tendency to lose their gaskets around 100,000 miles, although many have gone well above that. You would be safer with a 5% pulley, and with those mods, that would not be a significant reduction from 10%. Before doing a pulley at all however, the intake should be upgraded to a cone filter and larger hose, TB, ect. This will make a pulley more efficient, since its goal is to try and push more air into the engine. It also is a way to increase power without reducing gas mileage or life expectancy.
    Sep 2002
    florida
    17
    Could you explain about the larger hose, TB, etc I really donít know all that much about the significance of these mods but I am anxious to learn?
    This was not the car I was looking to buy, but once I saw and drove it I had to have it. I'm hooked.
    Scott
    Edmonton, AB, Canada
    287
    although he should be explaining these...i'm in hopes he's answering my questions so i'll try to explain a lil
    he meant that you should increase the air flow in your intake by getting a better intake system (cone type k&n filter and better tubing)
    below is a picture of one intake system from www.supercoupeperformance.com
    the above will let/get more air into your car more efficiently, and having a larger tube also lets more air pass thru/per second.
    Next to keep this newly increased airflow flowing nicely....you have to increase the size of the throttle body. Basically i see this as a circle....the bigger the circle...the more air you can push thru in a given time. Thus getting a larger throttle body will allow more air into the car. (see below)
    stock:60mm TB
    80mm TB:
    having the above...and getting the increased amount of air into the car will make a 5% pulley more efficient and thus the pulley will make a larger difference.
    Hope at least some of that makes sense......i tried
    Illinois
    1,744
    Many people found a similar response after their first drive in this vehicle . As far as the intake is concerned, there are custom kits available which replace the current black air-filter box and air hose. The silver throttle body at the end of the air hose is smaller on some older model SCs, I believe its a 50 milimeter. Newer SCs and GT Mustangs have a larger one, again I think its 70mm. See this article for more information about our intakes. In all, a completley new intake system should yield a minimum of 1 psi over a mostly stock system. It will help even more with your higher flowing exhaust. As a guess, I would say a new intake with your exhaust may gain you another 10-20 hp, others can be more specific.
    Aug 2002
    Down by the river.
    311
    make sure your exhaust flows well and go with a 10%! dont live in fear of the headgaskets they are going to blow no matter what you do. My friend put a 5% on and said he barely felt any difference in it. just get a cat-back exhaust with hi-flow or no cats then run a 10% you will be fine.
    238
    yes....don't mess with the pulley until you do the exhaust....the center muffler must be eliminated or replaced with the SCCOA one or equivalent and also no cats makes a big difference.
    go to magnumpowers.com and get the 80hp add on deal, (summer special up till end Sept for about $1700) after that....that's the best follow-on after the exhaust.
    The other requirements are injectors and fuel pump as explained on the site....then you net something like 320hp between the exhaust and the magnum powers intake stuff.
