View Poll Results: HOW MANY PARTS DO YOU HAVE LYING AROUND WAITING TO BE INSTALLED?
Voters
106. You may not vote on this poll
  • 1-2
    14 13.21%
  • 3-5
    27 25.47%
  • 5-10
    12 11.32%
  • 11+
    53 50.00%
Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: How many parts do you have lying around waiting to be installed?
    Jun 2004
    PHARR, TX
    626
    Was wondering how many other people are like me with a bunch of uninstalled parts that haven't been installed for whatever reason. Looking at parts that are not replacement parts, like changing out the iac, crank sensor, water pump, etc. List what you got lying around to be installed and why it hasn't been installed.
    FOR ME,
    1. INSTALL MY COLD AIR DIVIDER THAT IS CUSTOM. NEED TO CUT THE OVAL HOLE NEAR FILTER INTO A LARGE 3.5 TO ALLOW ACCESS FOR METAL TUBE.
    2. LARGE AIR FILTER. MAKES K&N 9" LOOK SMALL.
    3. 80 C&L.
    4. 85MM MP TB.
    5. MP PLENUM.
    6. S - MODEL SC.
    7. RAISED TOP.
    8. HAVE 10, 7, AND 5% OD SC PULLEYS.
    9. 10% JS PULLEY.
    10. ALL NEW BELTS. WAITING ON RADIATOR INSTALL.
    11. 50LB INJECTORS.
    12. 8.5MM WIRES AND METAL WIRE LOOMS.
    13. KW DOUBLE IC.
    14. 2 8" PERMA COOL FANS. NEED TO GET WIRING.
    15. RACEWARE ALUM. RADIATOR. AND HAVE ALL NEW HOSES FOR INSTALL.
    16. MP TENSIONER SPRINGS.
    17. KOOKS MIDLEGTH HEADERS.
    18. FABRICATED EXHAUST FROM HEADERS BACK.
    19. 255LB FUEL PUMP.
    20. RACETRONIX UPGRADED FUEL PUMP WIRING KIT.
    21. ALUM. LARGER CAPACITY TRANS PAN. (JUST GOT IT)
    22. CASE OF ROYAL PURPLE ATF.
    23. TRANS. COOLER. NEED TO GET HOSE, CLAMPS, ETC. (JUST GOT IT)
    24. DD SCT CHIP.
    25. UPPER ENGINE GASKET KIT. NEED TO CHANGE OUT VALVE COVER GASKETS. DRIVERS SIDE HAS SMALL LEAK.
    26. AUTOLITE 103'S.
    27. 180 THERMOSTAT.
    28. BATTERY RELOCATION KIT TO TRUNK.
    WOW, LOOKS WORSE WHEN I WRITE THEM DOWN. MOST ITEMS ARE IN A CLOSET IN THE HOUSE THAT I DON'T LOOK AT. ALSO, ALMOST HAVE ALL PARTS NEEDED FOR MUSTANG LUG CONVERSION (SET OF BLACK SALEEN SPEEDSTARS) AND CONSIDERING GETTING IN ON THE GROUP BUY FOR THE MP 10% CRANK PULLEY. SURE I'M LEAVING SOME PARTS OUT BESIDES STUFF LIKE EXTRA A/C COMPRESSOR, ETC. ALMOST ALL MY PARTS HAVEN'T GONE ON DUE TO NOT KNOWING HOW TO INSTALL OR TO BE INSTALLED WHEN OTHER PARTS ARE INSTALLED. ALSO, HAVING TROUBLE FINDING A GOOD MECHANIC THAT KNOW'S WHAT THEY ARE DOING WITH THESE CARS.
    35th ANNY Auto UNDER 89000 original. # 3246
    May 2007
    Wichita, KS
    3,018
    wow, you've got a 13 second car in your closet.....
    my list is shorter:
    ported 95 blower
    10% OD
    innovate LC1 wideband
    moates quarterhorse
    dual in/single out resonator
    mark 8 front brakes, front/rear drilled and slotted rotors, ceram pads.
    Sep 2006
    Roselle, IL
    169
    Aluminum driveshaft
    ADDCO sway bars
    Cobra brakes
    Handbrake and cable (I'm recovering the leather too)
    Heads
    Cams
    Some misc. braces
    COP's
    A bunch of replacement exterior parts as well for when I paint it.
    Jun 2004
    PHARR, TX
    626
    [QUOTE=sinhumane;826414]wow, you've got a 13 second car in your closet.....
    IF IT'S A 13 SEC CAR WITH THESE PARTS INSTALLED IT'S PROLLY HIGH 13'S. BUT I AM LOOKING FORWARD TO HOPEFULLY NEXT INCOME TAX GETTING SOME DD HEADS AND CAM. AFTER THAT I AM SURE I'LL BE REALLY HAPPY.
    Jul 2007
    South IL
    1,574
    i got 6 14/14/40 inch boxes with small parts. 1 4/4/10 ft crate with large parts, an sc, heads, and intake in vacuum rap
    and still dont have enough parts
    NYC
    17,431
    I cant believe you didnt put the SC on yet.....bad boy
    Jun 2004
    PHARR, TX
    626
    thought I found a good exhaust shop but apparently its like all the other junk places. have a guy that can put blower on for me but need exhaust done 1st. wouldn't want to have to do head gaskets right now.
    May 2007
    Wilmington MA
    1,092
    Being a yougin', I usually put all my stuff in as soon as I get it. However, I still need to find a suitable tank for my methanol kit, so that's the only thing I have laying around at the moment.
    Sep 2003
    P-Town, MN
    2,511
    -Upper and lower control arms with ball joints
    -Powdercoated LECB and RSFB bracing (have had these for three years)
    -Finalize radiator shrouding
    It's only impossible until we do it.
    22-year SC owner - '93 SC AOD (non-locking TC). Same car, same original paint!
    Current setup: 12.550 @ 111.09, 1.917 60ft, no bottle.
    May 2009
    Brantford Ontario CA
    219
    - 3inch Exhaust - need cats and down tubes made up
    - 42# injectors - need calibrated MAF
    - Power Steering Pump
    - clear Corner headlights
    - Rear Red Light/Reflector
    - Soon to come - Polished Idler Pulleys
    Jun 2009
    Garden City, Michigan
    332
    1.7 roller rockers
    new motor
    s-port
    Jan 2004
    Outside KC MO
    5,791
    Hmmmmmm....where to start.
    SC
    1)357 on the stand. Thats the entire thing from carb to tailpipe. I will count that as 1. Air bags 2. 'luminum LCAs 3. Diffy 4. Hood 5 (and it has not even been cut yet). N20 6.
    That is my "get by" engine until the other two are done and I can build the 3.8 the way I want.
    White car
    Heads and cams. Call that one...screw it. the new 'luminum engine that is lying in the corner (need a set of NPI pistons for it to start). Call that 1. Converter under the table 2. Put the 3.73s back in 3. Headers/full exhaust 4. Throttle and cruise with the modified bracket 5.
    FSB
    HGs 1. Rino lining 2. Sound deadner 3. SC 4. Carpet 5. Solid axle/lift 6.
    Need I go on?
    SWS
    Buffalo, NY
    1,455
    parts lying around
    i have about $7000.00 in engine parts, mostly new! just waiting to do the motor 1 day! way to many other parts! T
    Oct 2005
    Spring Texas
    745
    I would have what you would call, an IKEA car.
    everything is apart.
    21,015
    I usually install my new stuff within a week of getting it.
  1. 1 Stop MN12 TBird Cougar Parts Shop!!!
    By ReDevilXR7 in forum Non Technical Forum
    Last Post: 04-02-2012, 12:34 AM
  2. 1995 SC Automatic with Lots of Parts
    By dklitzke in forum Cars for Sale
    Last Post: 09-15-2009, 01:32 PM
  3. Good parts cars wanted must be Flodida cars deliverable!
    By victor malvar in forum Want to Buy
    Last Post: 02-17-2007, 01:49 AM
  4. Parts - Must sell everything ASAP
    By HighOctane in forum Super Coupe Club of Ontario
    Last Post: 06-27-2006, 11:01 AM
