Results 1 to 15 of 16
Thread: New brake problem on my 93 SC
    21,122
    When doing burnouts at the track this weekend the brake pedal got very hard when I suddenly got off the throttle and onto the brakes to get the car stopped before the staging light box. For the first second or so it required about 5 times the normal pedal effort to get the car stopped, then the pedal softened and brakes started working like normal. Didn't have any problem on the top end of the track, probably because I don't get on the brakes quickly.
    I'm assuming this has something to do with not having enough vacuum going to the booster, or possibly the booster check valve not functioning properly. Any pointers from you guys that are familiar with this brake system on what to check or replace would be apreciated.
    Jul 2003
    Orlando, Florida
    1,967
    I had something similar happen to mine about 3 years ago when I was doing allot of auto-x, happened a couple of times never really did find out what it was but I replaced the check valve for the heck of it and it has never happen since. You could check it and see.
    Norcross, GA
    3,326
    Are you using line locks? If so a solenoid may be sticking.
    21,122
    Quote Originally Posted by Mike Puckett View Post
    Mike,
    Nope...the brake system is stock except for the 13" Cobra brakes on the front. This car never has had very strong brakes but they were always good enough that it felt safe, until this started happening.
    21,122
    Quote Originally Posted by Flip View Post
    I agree that sounds like the easiest place to start.
    Oct 2006
    va beach,va
    2,585
    Sounds like you are on the right track to me. Would have to be the booster or the check valve to the reservoir. Do you have a larger reservoir installed due to the power adder? You could always pull vacuum on the booster and check it.
    21,122
    Quote Originally Posted by frdlvr30 View Post
    I was talking about this with Rod earlier today and he asked me about the vacuum reserve tank that's supposed to be up in the passenger side fender. There is no tank there and it was most likely removed by those jokers in Dayton who originally built the turbo system. Those guys didn't relocate stuff that was in the way, they just tossed it.
    So in addition to the check valve I'll be looking for a larger than stock vacuum tank. Looks like I've got plenty of room to mount one behind the driver's side of the front bumper cover.
    Oct 2006
    va beach,va
    2,585
    The never ending story, huh? Thats you problem David. Especially in situations like that where you are going from WOT to braking immediately. The booster will never hold enough vacuum within itself for situations like that. Plumb yourself a reservoir with a check valve to manifold vacuum and it will be solved...How did the car do otherwise? Other than Im guessing, some traction issues.....!!!
    Edit- I read your post on the other thread. Man that thing will fly!!! I like how you accidentally went 11.2 at 100mph (Obviously seriously pedaling it!!) Is that car getting any kind of twisting damage??
    21,122
    The car did fine, but it's still a little slow getting into full boost when launching from a dead stop. In the past I was able to get as much as 12 pounds of boost on the trans brake, but now I'm only getting about 5. Some of that is probably because I disconnected the electronic boost controller which was programmed to hold the wastegate closed until it reached 14 psi. I plumbed in a manual controller that doesn't have that ability, but it doesn't do any of the goofy stuff the electronic controller did either, so I like it better. On the street it easily spins the tires from a stop without any boost and once the rpms get over 3500 and the boost starts hitting hard it instantly pegs the tach. On the track (with drag radials) it doesn't spin the tires off the line, but does spin them on the top end of 1st gear.
    I think I can get it to do a better job of launching by tweaking the tune a little (leaner and more timing advance) and raising the rpms a couple hundred on the 2 step rev limiter. Once I turn the boost up, I think I'm going to need some 28" or 29" slicks to stay off the 6800 rpm rev limiter on the top end of 3rd . It really depends on how much converter slip I'm going to get.
    At this point I'm launching fairly soft (1.7 60ft), so there really isn't any twisting and the stock halfshafts seem to be holding up fine. Probably will start having some problems if I can get it to start pulling 1.5 60fts, but I'll cross that bridge when I come to it.
    Back to the brakes....do you are anyone else here have a vacuum diagram showing how the vacuum canister and brake booster are supposed to be plumbed on a 93 SC ?
    Boston, MA
    7,488
    Dave what canister are you talking about the only canister I know the car has is for the cruise control. I had to make myself a generic one when i had a larger then adequate camshaft. I am unaware there is a factory canister for the brakes.
    21,122
    Ditto...I'm just going by what I was told. Anyone else care to confirm or deny the existince of a vacuum canister on a 93 SC ?
    Jul 2003
    Orlando, Florida
    1,967
    I have never found one on my 93 and there is no reference to one in the factory service manual.
    21,122
    Okay thanks for clearing that up.
    21,122
    Ricardo,
    How much better did your brakes work after adding the vacuum canister ?
    Boston, MA
    7,488
    Marginal, it was not a fix but a slight band aid. It helped at times but if I used up all of it like going down an incline with the brakes applied I would loose them near the end of the incline. Scary.
    Get a big enough canister to handle it but problem I found is placement.
    93+ ABS brakes IMO suck although much more reliable. I think the earlier cars offers better brakes even with the small rotors.
  1. strange brake problem
    By nitrouspaul in forum Technical Forum
    Last Post: 05-25-2008, 09:50 PM
  2. Second time with this Brake problem
    By TbSCbos13 in forum Non Technical Forum
    Last Post: 01-07-2005, 03:03 PM
  3. Brake problem...NOT Accumulator????
    Last Post: 02-13-2003, 05:53 PM
  4. Brake Problem... Need help ASAP!!
    By supercoupe92FL in forum Technical Forum
    Last Post: 02-03-2003, 01:05 AM
  5. ABS / Brake Problem
    By 93scto in forum Technical Forum
    Last Post: 07-02-2002, 09:27 AM
