Mark VIII LCA's / Delrin Bushings / UHMW Perches
DLF
I made up another set of Mark VIII LCA's with Delrin Bushings and light weight UHMW Spring Perches. These are the shorter perches (not for use with AirLift air bags).
MN-12 LCA's weigh more than 23 lbs., these are just over 17 lbs. with the perches, so you can save ~12 lbs. of unsprung weight.
I have no more Mark VIII LCA's in stock, so this is the last set.
$625 Shipped (lower 48).
Add $25 for taller perches for use with air bags.
Also included, the correct Mark VIII Torx LCA to Knuckle bolts.
I just came across another set of Mark VIII LCA's, so I'm in the process of making another set of these.
Same deal, Delrin Bushings installed, Short UHMW Perches, Torx bolts.
$625 shipped (lower 48) +$25 for Tall UHMW Perches.
Sold.........
I've just come across another set of Mark VIII LCA's, so I'm in the process of making another set of these.
Ready to ship.
SOLD
However, I have LCA's in stock and can make another set....
SOLD
Here's another set that I just finished and sold.
And here's a pic of a set that's going out on Monday. :cool:
