Results 16 to 26 of 26
Thread: guys, help with upper control arm...please!
    Mar 2017
    Sweden
    9
    Thank you, that's very much appreciated. It's hard to find stuff around here.
    I checked the nut from under the car, and I could see it but I couldn't reach it (I don't have a 3 foot 18mm wrench ). So I ended up doing it from above, but I needed assistance to manipulate the ratchet inside the fender at the same time...
    I put it together with the old bloated bolts and nuts for now. I guess I will have to deal with all the stuff under the hood that I dislodged tomorrow.
    Denver Area
    803
    I've done them on two birds now. I pull the strut assembly every time. Once you have the strut out you can hold the 18MM wrench above while you ratchet below. It's difficult but it works. Let me know on the bolts.
    2,218
    Or you can, you know, leave the flags on, and then all you need to do is use the 18mm ratcheting box wrench ...
    Mar 2017
    Sweden
    9
    Yeah, I did on the front one, but that didn't work on the rear one.
    Denver Area
    803
    I would have had I had an 18mm ratcheting box wrench.
    Jan 2015
    Tidewater area, Virginia
    230
    Quote Originally Posted by onkelmicke View Post
    And no I didn't get a new one. Where would I get one of those bolts?
    you don't. There are maybe 5 or six OEM in the country as of last year. A new bolt should have been included with the UCA, did you keep the packaging?
    95 5spd Pearl White SC, "Millennium TBird" (erst Dr. Jekyll)
    95 Automatic Red SC
    2,218
    Onkelmicke - I was cussin' the accumulator for the A/C, and the Teves Mk II I had when I did my first LCAs, but otherwise, it was doable.
    Potschotscott - for your next time, GET ONE. I'm surprised you even tried without; it's almost impossible to get into the side at the ABS unit on a 1st gen WITH it, and I'd hate to try a 1st gen WITHOUT it.
    Denver Area
    803
    I have two 1994 birds - maybe that's why I managed without. That or I used to do Avionics in the Navy. I swear some of the stuff was hovered/levitated and then they built the aircraft around it.
    https://en.wikipedia.org/wiki/Northr..._EA-6B_Prowler
  9. #24
    Mar 2017
    Sweden
    9
    I will have to do the drivers side when I can get the LH UCA for it. And yeah the ABS looks to be in the way.
    Did you manage to get the correct torque on the nut with the flag left on the bolt?
    Onkel
  10. #25
    2,218
    Onkel
    What I did was to torque the front one to the bottom of the torque range, then use my ratcheting box wrench to snug it 1/8 turn.
    I then tightened the REAR nut to the same "feel".
    (I also cheated some; since I was reusing the old bolts, I use Blue LokTite(tm) on them.)
    One more thing is to either do this before attaching the ball joint to the spindle, so you can position it straight out and preload the bushings properly (the way the factory service manual says), or to do it after the car is sitting on the ground (and leave them loose until then), again, to make sure the bushings are preloaded properly.
    (I like the "Point'em straight out" method myself; if you break the flags off, you SURE can't get it right sitting on the ground!)
  11. #26
    5,692
    Onkel
    Torque the nut.. if you can. Otherwise what I did was using a 3" extension, and 6pt socket, reached behind the spring with the ratchet and tightend it up as much as I could, then with the torque wrench. I put a loose monkey wrench on the nut to just sort of hold it still while I torqued the bolt.
    Oh, and on the side with the ABS, I groped around with my fingers and guided the big monkey wrench onto the nut. Then let go and torqued the bolt. It held well enough to get the job done.
