Results 1 to 4 of 4
Thread: main bolts
    Jan 2006
    Clinton twp. MI
    12
    main bolts
    Has any one ever had any success with reusing their OEM main bolts and/or head bolts. I haven't seen any thing about them being a torque to yield bolt. I have always replaced with ARP studs or new bolts, but this is a budget build and I am looking to reuse with high mileage success.
    Jun 2009
    Toledo, ohio
    469
    I don't be leave you can reuse any head bolts. i for got why though lol.
    Jun 2009
    Toledo, ohio
    469
    found it.
    Do not reuse the cylinder head bolts. New cylinder head bolts must be used. The cylinder head bolts are torque-to-yield bolts and cannot be reused once the initial torque is applied. During the initial torque of the cylinder head bolt, the cylinder head bolt is stretched to achieve proper clamp load, which will not be achieved if a used cylinder head bolt is torqued again. A stretched cylinder head bolt can also break when torqued. Failure to replace the used cylinder head bolts with NEW cylinder head bolts can lead to improper clamp loads and extensive engine damage.
    Sep 2004
    Indy
    5,623
    Everyone that knows better will suggest that you use ARP head studs, which are reusable. The factory head bolts ARE NOT reusable. I have reused the main bolts with success, so I'm sure they are reusable.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
  1. My head gasket how-to
    Last Post: 05-15-2009, 01:18 AM
  2. Need the stock number for ARP main stud bolts for a 94 sc
    By nickleman60 in forum Technical Forum
    Last Post: 06-23-2008, 08:06 AM
  3. need main cap bolts w/ studs
    By WiscoAndy in forum Want to Buy
    Last Post: 04-22-2006, 12:06 PM
  4. rebuilding engine (any tips)
    By creeperxr7 in forum Technical Forum
    Last Post: 11-15-2003, 12:23 AM
