John Machen
I know someone wants or needs this 1990 SC, I currently don't have the time available to fix the few problems, that and I don't live near where the car is located.
Recently rebuilt 5 speed, very good Kumho ecsta tires
No brakes, but comes with a spare master cylinder assembly.
Starts up easy and runs good. There is a coolant leak under boost, where boost pressure gets into the cooling system, no leak if run in vac only.
Borla exhaust system
All stock body panels in good shape. A little clear coat failing on driver fender.
New larger injectors, 70mm aftermarket throttle body, cold air inlet (older SCP style), ported exhaust manifolds, new DIS, new harmonic balancer, new coil packs and many other spare parts.
The car is located in Mathews VA and can be driven but not safe until the brakes are repaired, so it could be easily loaded on a trailer.
This is being posted for my dad and brother.
Email machend@aol.com for pictures and additional details.
Best offer.
Thanks,
John
Best offer.
Thanks,
John
