Results 1 to 15 of 24
Thread: First ever run at the track
    Jul 2009
    Mooresville, IN
    120
    So, I decided to take my 1990 SC to the track on Tuesday. It is all stock and I wanted to see what it would run before i started doing any upgrades to it. Here is the best run the car had, keep in mind that this is the first time I had ever been to a track to race. It was about 90 degrees outside so the car was running warm. Also, I was running on street tires without doing a burnout.
    R/T .551
    60' 2.341
    330 6.736
    1/8 10.318
    MPH 69.05
    1000 13.391
    1/4 16.007
    MPH 85.91
    What would be the best thing to upgrade first. I want to eventually get the car into the 14's. I have a cold air intake sitting in the garage that will be going on this week. If I upgrade the pulley will it cause the head gaskets to blow quickly?
    St. Louis, MO
    6,481
    Looks a lot like the first pass I ever made at the track.
    There are numerous threads about suggested upgrades. Personally, I always recommend underdrive pulleys as an early mode.
    Kurt K (e-mail)
    SCCoA Member #: 443
    Apr 2004
    sumter, south carolina
    3,050
    auto or manual ?
    heres what i would do :
    -intake (even a K&N panel filer will be enough)
    -5% sc od pulley
    -fan on back of the intercooler
    -exhaust-get some straighter downtubes made, with or without hi-flow cats. then get a good aftermarket resonator. leave the back half alone, it'll flow fine for now.
    Oct 2004
    Charlotte, NC
    8,159
    Learn how to lower your reaction time....
    Try leaving as soon as you see the first yellow light up....
    I have the same set up as yours and got my reaction time down to a .023
    One word of advice, do not put your trans in OD when running at the track.....
    Leave it in D....
    Jul 2009
    Mooresville, IN
    120
    Quote Originally Posted by thunderkid84 View Post
    auto or manual ?
    -5% sc od pulley
    It is an automatic.
    Apr 2004
    3,050
    Quote Originally Posted by cyoder View Post
    It is an automatic.
    ok. yea just do what big e says and whats on my list. you'll be surprised the difference that stuff will make.
    Jul 2009
    Mooresville, IN
    120
    alright thanks for the advice.
    Sep 2004
    Indy
    5,623
    Reaction time doesn't have anything to do with your ET. I would put a CAI, custom downtubes, exhaust, double intercooler, and a late model blower. The exhaust and late model blower (blowers from 1994/1995 SC's) will be the best route to go with.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    Apr 2004
    3,050
    Quote Originally Posted by CMac89 View Post
    I was tryin to keep costs down. But yea a late model sc would be great. You can get one for about $250
    Queens, NYC
    1,058
    The easiest upgrade you can do is to learn to drive your car.. Practice practice practice and you will knock 1/2 second off that ET easily on street tires..
    Lakeville, MN
    13,517
    If it still has the stock balancer on it, start setting aside money from each pay check to buy a replacement BHJ. Eventually that stocker will fail on you.
    Along with that I'd be setting aside some money for a Lentech valve body for your transmission. You don't want your trans shifting into overdrive when doing a WOT run down the track. And it's a nice upgrade, though costly.
    While saving for those things, and assuming all the regular maintenance stuff on your car is taken care of, underdrives will be a nice upgrade. A 5% overdrive Jackshaft pulley or blower pulley would work well. A new, shorter A/C condenser would allow your stock intercooler to work much better and an IC fan to cool things down after a run down the track.
    My best time with my 90 auto with a 5% overdrive pulley and lentech valve body, custom down tubes, 2.5 - 3 - 2.5 exhaust, and MT ET Street tires is 14.667 at 93.89mph.
    If you have a membership here, this thread is well worth the fee where XR7 Dave took a bone stock SC, and did mods to it, with dyno runs to see what worked, and how much.http://www.sccoa.com/forums/showthre...t=air+silencer
    This thread gets interesting around post 32 or so on other peoples ideas of the mods to do:
    http://www.sccoa.com/forums/showthre...ighlight=track
    Jul 2009
    Mooresville, IN
    120
    i have decided that the first thing i want to get done is the exhaust. i want to get it professionally done because i dont have the time to do it myself and i dont really want to mess anything up. what is the best size pipes that i can tell them to put on. my grandpa got stainless steel flowmasters on his truck and it costed him a little less that 600 dollars. Is that a good price?
    Lakeville, MN
    13,517
    Stainless Steel prices are up now, so I'm not sure what it would cost you. the SC requires some bends, more than what a truck would so I would expect the cost to be a bit more.
    Hopefully someone will pipe up on exhaust pipe sizes. I went with 2.5 into 3" into 2.5" on my 90 sc. But there have been many threads regarding exhaust pipe sizes, and I can't recall what the latest thought is.
    Apr 2004
    3,050
    First off, leave the pipe after the resonator and around the gas tank alone. It's 2.5in which is plenty for now.
    Have them make new downpipes, 2", with or without cats depending on your state. And then get a dual in/single out aftermarket resonator with the appropriate sizes.
    After that it's up to you if u wanna change the mufflers out also.
    Apr 2004
    3,050
    I figure it should be about $400 with cats and resonator included
  1. New Motor, First time, first run, a 13!
    By Mike8675309 in forum Racing/Track Results
    Last Post: 09-25-2007, 01:42 PM
  2. Track day Turnout.
    By T1Bird in forum Super Coupe Club of Ontario
    Last Post: 06-15-2007, 12:54 PM
  3. Went to the track tonight....
    By ss_scuba in forum Non Technical Forum
    Last Post: 10-18-2006, 12:36 AM
  4. Video of my car at the track last week
    Last Post: 08-19-2004, 11:05 AM
  5. 2nd time at the track (milan). 14.887@93.95 MPH.
    By 91BLOWNSC in forum Non Technical Forum
    Last Post: 05-18-2002, 02:11 AM
