Results 1 to 15 of 21
Thread: Victor Malvar and any of his supporters CAN KISS MY ~~~!
    Boston, MA
    7,483
    Sound kewl
    Jun 2009
    Toledo, ohio
    469
    now will you have pro's vs con's on why this upgrade would be good over stock, + price vs hp increase, and stuff like that?
    yes i will provide as much information as possible
    Aug 2002
    3,669
    Is this intake manifold going to be for N/A cars or for our supercoupes?
    Aug 2005
    Chesapeake, VA
    1,976
    Is this a completely new intake?
    If so did you remove the egr passages from the intake, since the egr input on the SC setup is on the inlet elbow.
    Aug 2005
    Chesapeake, VA
    1,976
    Quote Originally Posted by suprchargeit View Post
    no, it WILL NOT be a new cast intake and it will not change anything on the egr systems for the earlier sc's
    So this will be an adapter plate for a splitport intake to utilize the SC intake elbow and mounting points for the M90?
    Aug 2005
    Chesapeake, VA
    1,976
    I guess I'm confused as the factory spltiport intake is a nightmare of passage routing. With it's integral egr passages and placement of the coolant ports, there is an intake port in front of the coolant port on one side.
    Jun 2009
    Toledo, ohio
    469
    that's cool i can't wait to see the numbers.
    Jun 2009
    Toledo, ohio
    469
    looks good!
  1. I found this FAQ on the SC
  2. Head Swap
    By SCPilot in forum Technical Forum
    Last Post: 05-13-2003, 11:45 AM
  3. Problems after head swap
    By 6pak2go in forum Technical Forum
    Last Post: 08-23-2002, 04:58 PM
