Results 1 to 5 of 5
Thread: Why is my car smoking?
    Feb 2004
    Glasford, IL
    267
    Question Why is my car smoking?
    So, I finally got my car running last night. I let it sit and run for about ten minutes. It smoked for a few minutes when I started it up. Out the exhaust and from the motor. The car hadn't been started in maybe over a couple years. So I backed it out of the garage today and let it idle for a bit hoping to burn whatever bad gas out that was left in it and I noticed the smoking has gotten worse. It's coming from both sides of the motor down near the exhaust manifolds. Could this be blown head gaskets? There is no water in my oil and my coolant bottle isn't overflowing like symptoms of a normal blown head gasket situation would show. I'm kinda nervous here. Can anyone help me out?
    Boston, MA
    7,526
    Get a fire extingusher if its not comming out of the tailpiles its just oil and other junk sitting on the manifolds burning off. I would run it with a extingusher next to you It shoud just vaporize and tame down. I get scarred too but it burns away. leaking valve covers will cause oil to drip onto the exhaust and cause that.
    Feb 2004
    Glasford, IL
    267
    I think that's what it is. Dealership told me there was only the ICRM wrong with this car...WRONG! All the brakes need redone, the power steering pump is going out, the shifter needs rebuilt, the crank sensor was bad and now it's smoking. Ugh! I hope this list of things that are wrong STOPS where it is!
    21,151
    Quote Originally Posted by MustangJake88 View Post
    Rocker cover gaskets are probably leaking and oil is dripping down onto the exhaust manifolds.
    Feb 2004
    Glasford, IL
    267
    That's what it almost looks like. I noticed the lips on my valve covers are pretty sludgy. I'll pick up some good Fel-pro gaskets for them tomorrow when I have my rotors turned.
  1. Ford returns the Thunderbird to the Future Product vault
    By Birdman93 in forum Non Technical Forum
    Last Post: 01-13-2014, 02:56 PM
  2. The path to 450rwhp...or at least mine.
    By XR7 Dave in forum Non Technical Forum
    Last Post: 03-23-2009, 05:16 PM
  3. Car fire on halloween-burnt shell remains
    By Charkly in forum Non Technical Forum
    Last Post: 11-04-2004, 11:56 AM
  4. Car won't start!
    By sc0tty8 in forum Technical Forum
    Last Post: 06-21-2004, 11:42 PM
  5. car smoking and knock sensor question
    By Bacondoggy in forum Technical Forum
    Last Post: 10-03-2003, 06:22 AM
