Results 1 to 9 of 9
Thread: Stock Cam and Roller Rockers
    Mar 2009
    Tacoma, WA
    558
    I have an 89 5speed and I have found on this website that my cam is as follows:
    89 Manual
    Intake .448", 194 @ .050", ICL 106
    Exhaust .457", 202 @ .050", LDA 110
    I understand the first two numbers, but what is the .050" and ICL and LDA mean? And then second of all, if I wanted to use Roller Rockers to increase the lift and reduce valvetrain friction with stock valves and springs, what would be the limit in terms of ratio? Or what would you recommend? I'd rather not replace the cam but if I could get the same results or better for less money I'd be open to it. It just seems like it might be a bit of a job.
    Jun 2007
    275
    Harland Sharp and Morana have 1.8 ratio rockers but might require different studs and possibly machining. There are some previous posts. Cam would be cheaper, unless you miss the allen head bolt on the timing cover under the oil pump.
    The stock valve springs are only capable of .520 lift, in good condition.
    Mar 2009
    Tacoma, WA
    558
    Quote Originally Posted by Stupid Canuck View Post
    Well after reading some more posts about cams and rockers I came to the same conclusion. And I did catch that allen head bolt in a couple people's posts :-). I'm not ready for the cam yet but I want to get it all planned out in advance so i'm not sorta throwing parts on helter skelter. I'm trying to get things that compliment each other and such. I know that the Roots style blower is very sensitive to inlet restrictions, and since it doesn't pressurize the air, less boost as a result of things after the supercharger is a good thing actually, and Cam came to mind. I'm starting on my exhaust this sunday, so we'll see how that goes. Thanks for the reply
    Apr 2004
    sumter, south carolina
    3,051
    What are your plans for exhaust ?
    Mar 2009
    Tacoma, WA
    558
    Well for the imediate future, simply getting rid of the resonator, since that has the most restrictive part of the exhaust on it, and the crimp, but my plans are to run 2.25 or 2.5" downtubes to a magnaflow or similar muffler as the resonator, and then Borla or Flowmasters for the mufflers. At the magnaflow, I'll probably go to single 3" or similar. That's for next summer. The cam is along the same timelines, but I want to get research done ahead of time.
    Apr 2004
    3,051
    Sounds good.
    The best thing u can for your sc is to read all the info u can on these forums.
    It's a great community of friends too.
    Mar 2009
    Tacoma, WA
    558
    So I still a little confused as to what all the numbers on the camshaft specs are. Can someone explain them to me? I know what lift and duration are, but what are the other two?
    Jun 2007
    275
    Duration @ .050 lift (or more) ... standard rating stuff
    Forget the anagrams but the last numbers are lobe separation.
    Mar 2009
    Tacoma, WA
    558
    ooh now I get the .050 part. Thanks for the help
  1. comp cam roller tip rockers sold
    By 92sclikenew in forum Parts for Sale
    Last Post: 08-15-2009, 05:31 PM
  2. cam, roller rockers, pushrods, intake
    By Kevin Leitem in forum Parts for Sale
    Last Post: 01-22-2008, 05:54 PM
  3. Cam or 1.73 Roller Rockers?
    By bigpoppa822 in forum Technical Forum
    Last Post: 05-29-2007, 08:43 PM
  4. crane cam energizer roller rockers
    By creeperxr7 in forum Technical Forum
    Last Post: 05-20-2004, 03:18 PM
  5. roller rockers with cam?
    By T-bird4vr in forum Technical Forum
    Last Post: 01-06-2004, 07:34 PM
