Ok as the title states i need one of you guys who have rebuilt many of these motors to explane to me how to retime the motor. Ive had the marks on the crank and cam gear lined up then set the cam sensor up like in the pics and after it was all together it would backfire through the exhaust. so i tought it was out of time so i retimed it on compression stroke with intake valve and exhaust valve closed on #1. Got it together again and still backfire. But now i have been reading on here (link enclosed)
http://www.sccoa.com/forums/showthread.php?t=107752&highlight=timing+chain
Now this is where i found the timing marks had to be lined up but im confused on if it should be on compression stroke or not. Also can someone explane the cam timing in more detail than this
http://www.sccoa.com/forums/showthread.php?t=46483
Thanks ahead of time for your time.
