Results 1 to 15 of 18
Thread: accumulator instalation
    Sep 2008
    brevard north carolina
    13
    just got the accumulator in the other day and before we try and put it in is there any tricks or anything special that needs to be done to switch them or is it pretty straighforward? thanks guys
    Salem OR
    6,886
    Good news is, you don't have to bleed the system when changing out the accumulator.
    I recommend removing at least the driver's side cowling to help gain access, etc. You'll need the proper driver to engage the top of the unit (8mm?) - clean out that hole good first so you have proper purchase when turning.
    Remove wipers, rubber trim, and driver side cowling (screws from top/corner and one horizontal inside) etc. first to give yourself more room to work...
    Pay attention to these points:
    • Be sure to bleed down/off any residual pressure before removing the old accumulator. It can take dozens of pumps on the brake pedal (key off of course) to get this done, so take this seriously. Wrap a towel you don't need around the base of the accumulator to catch any spray that may result from remaining pressurized fluid.
    • Do not leave the system open and use care to not let any dirt/debris fall into the open port. Have the replacement accumulator, tools etc. ready to go.
    • Be sure the replacement accumulator has a fresh brake fluid safe (EPDM) o-ring (Size: -111) ...coat it with clean brake fluid before installing.
    • Start it with your hands to be sure to properly engage the threads and do not force it. Tighten the replacement accumulator as tight as you can with normal tools. Do not over-torque. Some replacement accumulators don't have a tool purchase, so a strap wrench is your best friend in those cases.
    • When the replacement is installed, fill the brake fluid reservoir near to the top with the correct fluid, replace the cap and turn the ignition key to run. It can take a surprising amount of brake fluid to fill an accumulator so have plenty on hand - don't let this procedure empty the reservoir. Wait for the motor to stop running and the light(s) to go out (1 minute or so?), indicating that pressure has built up and shut off the ignition. Check for any lights and if they don't go out stop...don't let the motor run too long to prohibit damage from overheating.
    • Check for leaks and repeat the key on procedure to confirm the pressure is holding and building as normal...check for proper warning light operation again.
    • Check the brake fluid level with key off and the unit charged....add or remove any fluid required to set the level at the indicated marks on the side of the reservoir.
    • Test drive with caution until you feel the system is operating properly. Watch the level for a day or so and re-check for leaks etc. before enjoying your work.
    Replacing an accumulator is a relatively straight forward procedure, esp. after doing it once. Just like any brake work, tho, it is important to use care in the process.
    Oct 2004
    Charlotte, NC
    8,159
    That was a very good walk thru of the installation process....
    Nov 2009
    Metropolis, IL
    884
    thanks
    Remove wipers, rubber trim, cowling (screws from top and one horizontal inside) etc. first to give yourself more room to work...
    Be sure the replacement accumulator has a fresh o-ring...coat it with clean brake fluid before installing.
    Tighten the replacement accumulator as tight as you can with normal tools. Do not over-torque. Start it with your hands to be sure to properly engage the threads and do not force it.
    When the replacement is installed, fill the brake fluid reservoir to the top with the correct fluid, replace the cap and turn the ignition key to run. It can take a surprising amount of brake fluid to fill an accumulator so have plenty on hand - don't let this procedure empty the reservoir. Wait for the motor to stop running and the light(s) to go out (1 minute or so?), indicating that pressure has built up and shut off the ignition. Check for any lights and if they don't go out stop...don't let the motor run too long to prohibit damage from overheating.
    Check the brake fluid level with key off and the unit charged....add or remove any fluid required to set the level at the indicated marks.
    Just what I needed to know. I am very thankful to be on a site that helps as much as you all do!
    US Navy Veteran Retired Best Dyno 458HP 556TQ
    "I've done so much with so little for so long that now I can do anything with nothing."
    http://www.sccoa.com/forums/garage.p..._view&id=28414B
    Nov 2009
    Metropolis, IL
    884
    Done
    That was too easy! Thanks for the help. You guys are the best!
    Oct 2006
    Atlanta, GA
    63
    This is good set of instructions. Very helpful for me.
    It is important to use EPDM o-rings not the standard buna-n. They will last longer and seal better with brake fluid. I got mine from Mcmaster-carr.
    An additional trick is to mark the windshield before removing the wipers so you can get them back in the same place and install them before turning the ignition back on. .
    St. Louis, MO
    6,484
    Quote Originally Posted by hsommer View Post
    This isn't necessary if your car still has the plastic keyways for the wiper locations Of course, most don't.
    Kurt K (e-mail)
    SCCoA Member #: 443
    SCCoA Member#1257
    3,324
    Quote Originally Posted by Kurt K View Post
    plastic keyways???? Don't think i recall seeing any...like evar. Any pix?
    Sep 2014
    Broken Arrow, Ok
    196
    Just did mine this last weekend. It was easy and I have good brakes for the first time in years.
    Sep 2017
    Winnipeg, Canada
    1
    Where can I get an accumulator in Canada or USA?
    Salem OR
    6,886
    Quote Originally Posted by Motorizer View Post
    http://spinningwheels-sc.com
    Says out of stock, due late March, early April, contact Victor and ask if you can get on the list http://spinningwheels-sc.com/hydacaccumulatorballs.aspx
    Feb 2018
    6
    brake parts needed
    Hello I am working on a 1990 for a friend. I had the brake motor off and had fixed and cleaned up the mating surfaces and reused the square cut o ring. Of course it drips ever so slightly now. Does anyone know what size or part number I need for that? Also there is a junction block mounted a little ways below the booster assy for the rear brake line. It has a switch of sorts in the tee part of the block that is leaking also. Does anyone know a part number for this ? thanks everyone for your time. I can also be texted at 319.531.6399 scott
    Jul 2005
    430
    Good evening
    Contact SuperCoupe Performance for new brake pressure switch replacement. https://www.supercoupeperformance.co...ensor_300.jpeg
    Check out the below posts for pump leaking.
    http://www.sccoa.com/forums/showthre...s+pump+leaking
    http://www.sccoa.com/forums/showthre...ABS-Pump-Motor
    Good Luck.
    SCCoA Member#1257
    3,324
    Hey Ken,
    I received two accumulator balls from Victor & Diane at spinning wheels. I think I have everything ready except the strap to tigten. What kind of strap did you use? I figure we need to get this tightened pretty good in pace so wondering what kind of strap will do the job. Somehow I have a hard time thinking that a regular rubber belt strap will be enough. Last time I did this I used an OEM accumulator ball so I had the hex key bolt to tighten. The ones from Victor don't have this.
    Salem OR
    6,886
    Quote Originally Posted by CaifanSC View Post
    The type that can remove oil filters. Don't go nuts, just tight enough it won't come loose on it's own later.
    The ones that have a metal bar you can get a 1/2" socket extension into work for me.
    https://www.ebay.com/itm/GearWrench-...ench.TRS0.TSS0
    ...as opposed to the ones you lever by hand, since there's not much room to work.
