Thread: Accel Coil and Plug Gap
    Aug 2002
    Jersey Shore, PA
    1,875
    Okay, I know that when you put a higher voltage coil in a N/A car that you should open the spark plug gap to take advantage of the extra power the coil is putting out. Does this same practice apply with forced air cars? I'm planning on buying an Accel coil before I put my SC back on the road from some upgrades/maintenance that I am doing so I need to know so I can gap the plugs properly before I put them in and while their easy to get to.
    Aug 2002
    Jersey Shore, PA
    1,875
    I posted this before I went to work, so I didn't have time to do a search cause I was working on my SC before that.
    This is what I figured out. It'll help to get a better coil, it can smooth out the idle, smooth out the acceleration, and provide better fuel economy. Gap isn't such a big issue, Autolite 103's are a gift from God, and I should be able to open the gap from .035 to about .040.
    So I think it is a worthy investment and will be the last thing on my list of parts to buy so I can try to wrap this thing up in the next 2 week and try to get some fun time out of her before winter comes.
    NYC
    17,432
    I'd start with factory GAP and see if it works out..Then if you need to reduce gap. Dont go higher then stock
  1. Why Yes another sparkplug thread...
    By 91 XR7 in forum Technical Forum
    Last Post: 08-08-2008, 10:10 PM
  2. Do The motocraft plugs suck for anyone else?
    By DanzajaxTX in forum Technical Forum
    Last Post: 05-29-2007, 07:18 PM
  3. Accel Plug Wires
    By Jeff Bratton in forum Technical Forum
    Last Post: 09-12-2005, 08:23 PM
