Results 1 to 11 of 11
Thread: Flywheel bolt thread sealer??
    Oak Ridge, TN
    1,691
    I have a new flywheel and bought new mounting bolts from Ford that come with the sealer on them. The problem is due to mounting the flywheel/clutch once without the rear engine cover, aka seperator plate, and once with the wrong one, which thread lock or sealant should I use?
    Thanks,
    Kurt
    May 2009
    329
    Quote Originally Posted by XR7Kurt View Post
    Thanks,
    Kurt
    at AAMCO we just used red "locktite"...
    Aug 2005
    Sunrise Beach, MO
    2,289
    Red Locktite
    [B][COLOR="Blue"][COLOR="Red"]June 6, 2009....D-Day[/COLOR][/COLOR][/B]
    [B][COLOR="Blue"]1989 SC AUTO- Midnight Blue:D[/COLOR][/B]
    "They act like they are bed buds that have known me forever" -Corey B-
    Lakeville, MN
    13,517
    Personally, I used blue loc-tite. The factory thread lock isn't anything like the red stuff.
    Oak Ridge, TN
    1,691
    It doesn't look like any of the loctite products I've seen. It definately needs to have sealing capability as well as locking capability since there is a direct path to oil through the holes.
    Madison, Ohio
    17,691
    No, the bolt holes are blind and do not require any sealer. Ford did not put anything at all on the threads when new, and the new bolts I have here (5spd) do not have anything on them but that doesn't mean much. Anything they may have put on the threads could serve as a dry lubricant as well as a mild thread locker, but neither are necessary.
    Email me here.
    English, IN
    4,515
    Quote Originally Posted by Mike8675309 View Post
    I also used the blue loctite...while it may not be necessary, it makes me feel better.
    Matt Haub
    Shootouts: '09 SS 1st | '10 Mod1 2nd | '11 Bracket 3rd | '12 Bracket 1st | 2013 | '14 Bracket 3rd | 2015 | '16 Bracket 1st & Mod2 2nd | '17 Spectator | '18 Freeze-Plug Champ
    Black '89 5spd - 281K miles, MPx, Alky-Inj 387rwhp, 438rwtq (new motor) Best 1/4mi:12.521, MPH:107.23mph (old motor)
    Nov 2004
    Brantford, ON
    5,383
    I was under the impression that new bolts for the 5spd flywheels where not available anymore... is this true?
    Is there an alternative?
    Fraser
    Oak Ridge, TN
    1,691
    Sorry I left out that this was a 5.0 going to a 5-speed XR7, I thought it was a generic enough application, I guess there's no such thing anymore. The holes on this are definately not blind since nice clean oil ran out when I pulled one of the bolts out.
    I did some research last nite and couldn't find any discussion on the sealing properties of any of the choices only about which lock strength is needed. Blue, or nonpermanent, seems to be the choice rather than the more permanent red that is designed to be removed with heat applied.
    Madison, Ohio
    17,691
    I don't understand how you can ask a question like this without giving pertinent information. Of course not all applications are the same! The Ford application for the 5.0 is for a sealer, not a locker, although a locker can work as a sealer if you want it to.
    Many people use various locking agents on flywheel bolts because they do not trust the bolts themselves or they are not torquing correctly, however Ford does not specify anything be applied to the flywheel bolts (3.8L) nor did they ever come with anything on them. Adding locker because it makes you "feel better" doesn't improve the fastener's performance. Do you put lock tite on connecting rod bolts? I didn't think so, yet those bolts are by far the most highly stressed bolts in the engine. Instead ARP recommends you use moly lube on their connecting rod bolts. How about lug nuts? I don't believe we normally use any locker on those. If a bolt is torqued properly so that specified stretch is generated, no locking fluid is generally needed (or desired).
    Email me here.
    Oak Ridge, TN
    1,691
    I guess if I can do what I did in the first place I can do anything.
    I agree, I'm kind of a stickler about doing things as designed. Which is why I'm taking the flywheel off for the second time. Sure the cover/plate for the auto will get me down the road, but they made them different for a reason.
    Anyhow, thanks for the info, I'll just use some sealer.
  1. ARP Crank Bolt - Anyone running this?
    By Tim Groth in forum Non Technical Forum
    Last Post: 07-17-2006, 12:36 PM
  2. Trans crossmember bolt issues...how bad is this? (PIX)
    By CaifanSC in forum Technical Forum
    Last Post: 06-02-2006, 07:52 AM
  3. Broken Balancer to crank bolt
    By tganley in forum Technical Forum
    Last Post: 10-06-2005, 01:00 PM
  4. Knock Sensor Mount Thread sealer
    By farleye in forum Technical Forum
    Last Post: 10-03-2005, 10:51 AM
  5. clutch question???
    By aplvlydrtybird in forum Technical Forum
    Last Post: 02-01-2004, 08:29 PM
