Results 1 to 12 of 12
Thread: What stuff weighs
    Apr 2003
    Ventura, CA
    1,753
    What stuff weighs
    Over the last few years I've been waging a war against my car's portliness. I've shaved hundreds of pounds and using both 4-wheel scales and a more sensitive postal scale I've weighed just about everything I have that I've removed for some reason while working on the car. In the hopes that someone will find some of the information useful I've decided to post my findings here.
    Absolutely nothing on the list is conjecture or guessing; I have weighed every single part listed. Except for the few parts too heavy for my postal scale (ie a steel hood and assembled diff) all items have been weighed the same postal scale to eliminate variation between scales. The heavier items have all been weighed on the same pad of my 4-wheel scales.
    Note that if it isn't on this list I don't have the weight, so don't ask. If people want to expand this list with their own findings, all the better, though if your scales and my scales differ there will of course be conflicting information. All items, unless otherwise specified, were removed from a 95 SC. So in no particular order...
    Premium sound JBL speaker, each 3.10
    SN95 GT caliper w/bracket, no pads 7.80
    17x9 95 Cobra OEM wheel 22.40
    OEM 17x8 98 Cobra R wheel 22.00
    17x8 Voxx Misano wheel, painted 23.30
    98 Cobra 17x8 w/corded 255/45 A6 43.20
    95 Cobra 17x9w/new 275/40 A6 45.40
    10th anny Cobra w/new 255/45 F1GSD3 51.70
    LX Fan blade wheel w/225/60-15 yokohama 37.00
    94 SC wheel w/225/60-16 41.70
    Unused 275/40R17 Hoosier A6 23.60
    Stock rear diff cover 3.70
    Control Freak rear diff cover 7.90
    scp.com LECB, pair 4.40
    Rear belt retractors, pair 5.30
    Rear belt receivers/middle belt, set 1.60
    Rear seat lower, cloth 12.60
    Rear seat back, cloth 20.00
    Bilstein coilover tube/collar 0.70
    QA1 coilover shock 5.00
    12-600 HAL 2.5 ID spring 6.20
    Stock driveshaft 21.20
    5-speed aluminum driveshaft (4-inch) 16.50
    Braille B14115 battery 11.40
    Braille B14115 mount 0.70
    Group 58 Battery 28.60
    SC stereo head w/wiring 3.70
    Stock battery tray 1.40
    Koni shock insert 4.50
    Keyless entry module 1.80
    Computer (suspension) 2.00
    ABS computer 1.70
    Factory amp/subwoofer 13.30
    Ford Racing wheel center cap 0.10
    Al IRS Chunk, bare w/bearings 17.70
    Cloth/leather front seat, full power 55.80
    Detroit Truetrac diff 22.30
    Ford Racing 3.27 pinion 7.20
    Ford Racing 3.27 ring gear 10.40
    JBL audio tray thingy 3.00
    Front Cobra rotor 18.90
    Cobra front rotor 1 turn 2 bolt patterns 18.70
    Stock 95 hood 59.00
    VFN hood 26.00
    Stock rear diff assembly 78.00
    MY new rear diff assembly 72.00
    Stock alternator 13.50
    Floor mats 5.20
    Raised SC top 3.00
    Upper SC tube 4.70
    Lower SC tube 5.60
    SC side skirt bottom piece (plastic) 3.00
    SC side skirt door piece (metal) 1.30
    SC side skirt rear piece (plastic) 1.30
    Hood strut 0.50
    Aluminum rear LCA, stock 15.25
    Aluminum A-arm spring perch (stock) 3.40
    Stock SC front spring 13.50
    Stock SC rear spring 11.90
    Eibach front spring 13.70
    Eibach rear spring 11.00
    Vogtland front spring 12.30
    Vogtland rear spring 10.00
    Suspension Techniques front spring 14.30
    Suspension Techniques rear spring 11.60
    Hyperco 10-600 spring 5.10
    Radiator Express rad 15.40
    eBay aluminum radiator 8.90
    Double IC w/fan & wiring 20.00
    Stock intercooler 9.10
    Urethane spring perch 1.00
    Radiator fan 8.50
    Foglight & bracket 1.50
    St. Louis, MO
    6,388
    Was the raised top the cast MP variety or a "homemade" version? I imagine the cast top would be the lighter of the two.
    Kurt K (e-mail)
    SCCoA Member #: 443
    Apr 2003
    Ventura, CA
    1,753
    Definitely homemade.
    Forked River, NJ
    2,092
    Hmm, my postal scale says that the urethane isolator only weighs 8.2 ozs.
    Doh! I just realized that you're talking about the UHMW perches I made you....
    Oak Ridge, TN
    1,690
    I just found these the other day, there are lots of weights for different options near the end.
    http://www.sccoa.com/articles/scspecs.php
    I never thought about how much the moonroof adds, about 40lbs.
    Great information Will.
    May 2008
    Elkton, KY
    130
    Definitely some dedication there... or ocd...
    Apr 2005
    Western New York
    485
    thats just to better exact a shipping price
    Nov 2002
    Columbus, Ohio
    6,924
    Another good thread with weights can be found here:
    http://www.sccoa.com/forums/showthre...wrence+mansier
    Shane
    Adrian, Michigan
    1,359
    Just to add some info. I weighed the front passenger seat (leather full 6way power) and the rear seat bottom (again leather) out of my 95 SC.
    Front full leather passenger seat= 57.5 pounds
    Rear seat bottom leather= 14.5 pounds.
    The digital scale I used reads in 1/2 pound increments.
    SCCoA Member # 490 since 1997
    1995 SC (five speed) 12.8913@105.86
    Best 60' 1.7489
    1994 SC (automatic) 13.4829@100.23mph
    Best 60' 1.8539 On a stock long block with bolt on's
    http://www.sccoa.com/forums/garage.p...ge_view&id=638
    Jul 2007
    South IL
    1,571
    ok here you go, how much does the mother in law weigh in the trunk?
    Jul 2008
    Southern California
    264
    My big fat but = 196 lbs. nekkid
    My big fat but = 205 lbs. not nekkid
    Not so much for the Tbird but when I went to the Jim Hall Kart Racing school in Ventura, CA it sure made a difference when racing against those young 14 year olds. Annoyed the crap out of me when they crowed how much better drivers they were.
    Forked River, NJ
    2,092
    Valve Covers
    From my '95, off to repaint....
  1. stuff for sale
    By johnny o in forum Super Coupe Club of Ontario
    Last Post: 07-04-2005, 06:12 PM
  2. Replies: 15
    Last Post: 06-16-2005, 11:25 PM
  3. Extra stuff I have
    By JJanney in forum Super Coupe Club of Florida
    Last Post: 05-23-2005, 08:08 AM
  4. Stuff for sale
    By SCme in forum Super Coupe Club of the Southeast
    Last Post: 04-29-2004, 01:36 PM
