Mercutio
SCCoA Member
Over the last few years I've been waging a war against my car's portliness. I've shaved hundreds of pounds and using both 4-wheel scales and a more sensitive postal scale I've weighed just about everything I have that I've removed for some reason while working on the car. In the hopes that someone will find some of the information useful I've decided to post my findings here.
Absolutely nothing on the list is conjecture or guessing; I have weighed every single part listed. Except for the few parts too heavy for my postal scale (ie a steel hood and assembled diff) all items have been weighed the same postal scale to eliminate variation between scales. The heavier items have all been weighed on the same pad of my 4-wheel scales.
Note that if it isn't on this list I don't have the weight, so don't ask. If people want to expand this list with their own findings, all the better, though if your scales and my scales differ there will of course be conflicting information. All items, unless otherwise specified, were removed from a 95 SC. So in no particular order...
Premium sound JBL speaker, each 3.10
SN95 GT caliper w/bracket, no pads 7.80
17x9 95 Cobra OEM wheel 22.40
OEM 17x8 98 Cobra R wheel 22.00
17x8 Voxx Misano wheel, painted 23.30
98 Cobra 17x8 w/corded 255/45 A6 43.20
95 Cobra 17x9w/new 275/40 A6 45.40
10th anny Cobra w/new 255/45 F1GSD3 51.70
LX Fan blade wheel w/225/60-15 yokohama 37.00
94 SC wheel w/225/60-16 41.70
Unused 275/40R17 Hoosier A6 23.60
Stock rear diff cover 3.70
Control Freak rear diff cover 7.90
scp.com LECB, pair 4.40
Rear belt retractors, pair 5.30
Rear belt receivers/middle belt, set 1.60
Rear seat lower, cloth 12.60
Rear seat back, cloth 20.00
Bilstein coilover tube/collar 0.70
QA1 coilover shock 5.00
12-600 HAL 2.5 ID spring 6.20
Stock driveshaft 21.20
5-speed aluminum driveshaft (4-inch) 16.50
Braille B14115 battery 11.40
Braille B14115 mount 0.70
Group 58 Battery 28.60
SC stereo head w/wiring 3.70
Stock battery tray 1.40
Koni shock insert 4.50
Keyless entry module 1.80
Computer (suspension) 2.00
ABS computer 1.70
Factory amp/subwoofer 13.30
Ford Racing wheel center cap 0.10
Al IRS Chunk, bare w/bearings 17.70
Cloth/leather front seat, full power 55.80
Detroit Truetrac diff 22.30
Ford Racing 3.27 pinion 7.20
Ford Racing 3.27 ring gear 10.40
JBL audio tray thingy 3.00
Front Cobra rotor 18.90
Cobra front rotor 1 turn 2 bolt patterns 18.70
Stock 95 hood 59.00
VFN hood 26.00
Stock rear diff assembly 78.00
MY new rear diff assembly 72.00
Stock alternator 13.50
Floor mats 5.20
Raised SC top 3.00
Upper SC tube 4.70
Lower SC tube 5.60
SC side skirt bottom piece (plastic) 3.00
SC side skirt door piece (metal) 1.30
SC side skirt rear piece (plastic) 1.30
Hood strut 0.50
Aluminum rear LCA, stock 15.25
Aluminum A-arm spring perch (stock) 3.40
Stock SC front spring 13.50
Stock SC rear spring 11.90
Eibach front spring 13.70
Eibach rear spring 11.00
Vogtland front spring 12.30
Vogtland rear spring 10.00
Suspension Techniques front spring 14.30
Suspension Techniques rear spring 11.60
Hyperco 10-600 spring 5.10
Radiator Express rad 15.40
eBay aluminum radiator 8.90
Double IC w/fan & wiring 20.00
Stock intercooler 9.10
Urethane spring perch 1.00
Radiator fan 8.50
Foglight & bracket 1.50
ABS computer 1.70
Stock 95 hood 59.00
VFN hood 26.00
Floor mats 5.20
Raised SC top 3.00
Upper SC tube 4.70
Lower SC tube 5.60
Hood strut 0.50
Radiator fan 8.50
