Ddubb
Thanks guys, I appreciate the good remarks.
.. did some mork work last night.
Console on the left from a 94 5 speed SC, beat down very bad. Right one is from a 95 LX, fantastic condition. So I stripped them both down, drilled out the plastic welds on the inside plastic to outside with a countersink bit and pryed them apart .. then glued it all back together.
Console in the car, not fully installed yet. I cleaned up the plastic from the SC console base but it is still UV / weather faded .. I might try to find some trim paint to match a little better later.
Took a shot of the front end with the hood closed. No more headlight gap with the 97 lights / 94 hood.
Next to do, cut the mufflers off the LSC dual exhaust backhalf .. I have a pair of Cobra 03 bypass mufflers in the trunk of the car .. want to see how it sounds without mufflers first.
I put a little gas in it, and connected a few more wiring connectors under the dash to the engine bay. Need to check a couple more in the trunk, and currently charging up a battery to see if I can prime the fuel system .. more to come.
- Dan
- Dan
