Thread: help with staling
    Huntington Beach CA
    33
    help with staling
    the other day i went out to start my car and it was real hard to start it fimly did but at frist the tack dident move and after a 5sec. it was fine not yesterday i was at a red light and it staled so i put it inpark and it took a few trys and finly started and the tack did teh same thing agan dident work for about 5sec. or so and than worked fuine after that i'm thinking the cam sencer is that what is sounds like to you any help would be grate and how do you replace it to
    thanks Trever
    [email protected]
    Huntington Beach CA
    33
    sorry about the typing i was in a hury.
    Dallas, TX
    5,754
    The cam sensor is a piece of cake. Just unplug it, unbolt the old one and bolt on the new one, plug it back in. Its under the SC snout and it might have a tamper-proof bolt. If thats the case, you can either grind the nub out enought to get a regular torx bit in it, or Dremel out a slot across the head and use a screwdriver. Replace that bolt if you slot it though. This is about a 20minute job and that includes a 5 minute break.
