ricardoa1
I know there is much debate about IC that have inlets and outlets on the same side with a vertical core pattern. I guess id does not provide a long enough surface area to cool down the charge. But I am looking to see if this other same side IC design is better for Eaton applications over 20psi? It is an inexpensive IC and provided that the cores are of ok design is this design going to provide enough flow on our application to give us good performance gains. SC outlet temps will be very high on my application so I do think that the IC provides good surface area too cool down the charge, just not sure about flow. BTW another member has already fitted the IC on our cars and it seems to be a very good fit thats why it is attractive to me, since it does not reqire piping the whole car and it only needs a shorter condenser to keep AC and factory fan intact. The other SC application is a mild build so, and no data was ever pulled to see how well it worked, so I am now curious about it since i am interested. Any comments?
From thread....
http://www.sccoa.com/forums/showthread.php?t=109916&highlight=fmic
From thread....
