Results 1 to 8 of 8
Thread: headlight conversion 90 to 97
    Feb 2006
    St. Paul Minnesota
    42
    has anyone recently updated there front end? I just got a 90 sc and the front bumper and hood is junk so I fugured i will upgrade bumper to a 94-95 style with 96-97 headlights, I have the header panel lights and hood, and misc headlight wires from 97, do I just splice together the old ones? also does anyone know where I can get a 94/95 bumper cover??? near 55118 MN for less than $100
    Boston, MA
    7,534
    Ill be doing it to my 90 this weekend.
    Apr 2005
    Nor Cal
    2,985
    I just did a conversion about a month ago ..
    You'll need to cut the harnesses for the high beam / low beams and run the wires to the new harness .. I usually use one ground for the headlight, and take the other ground to use for the inner marker light - you'll need to run another line for the Inner running lighh also ( Brown wire ) from the wire for the running light lead on the Corner markers.
    - Dan
    Feb 2006
    St. Paul Minnesota
    42
    let me know how it turns out, what do you have to do for the headlights, to convert to one for both high and low beams? and what about the lights on the sides of the bumper?
    Feb 2006
    St. Paul Minnesota
    42
    could you send me some pics please? thanks
    Boston, MA
    7,534
    Quote Originally Posted by whitebird94 View Post
    It is really easy. The corner lamps dont need to be wired and the center lights can be tapped to the corner lights or dont use them at all. The headlights you will have 4 wires, a set of two. You will take the positive lead from each set to tap to the harness you grabbed from the junk yard. And all of the black ground wires can be tapped together.
    Ill try to document the wire colors but dont hold me too it, I will have my hands full this weekend I need to get this car on the road so i have a decent MPG friendly vehicle to commute to work.
    Feb 2006
    St. Paul Minnesota
    42
    finnally got a bumper cover $40, sweet
    Boston, MA
    7,534
    The wiring colors are the same on the earlier cars so thats makes things easier . Red is low beam positive and green is high beam positive. Use either black wire to for ground. I did not hook up the center lamps. Ill wire them later.
    Everyting is straight forward you will see how things are once you dig into it.
  1. 1990sc headlight conversion to 97 and hard shifting trans
    By whitebird94 in forum Technical Forum
    Last Post: 11-20-2009, 02:10 PM
  2. auto headlight conversion
    By decipha in forum Technical Forum
    Last Post: 12-06-2008, 12:57 AM
  3. 96-97 Cobra R hood NOW ON EBAY
    By CaifanSC in forum Parts for Sale
    Last Post: 04-16-2008, 12:57 AM
  4. Ford 'cheaps out' again...
    By Kit Sullivan in forum Technical Forum
    Last Post: 10-17-2007, 05:05 PM
  5. headlight conversion on a 95 to 96
    By YeYo in forum Technical Forum
    Last Post: 02-28-2003, 05:53 PM
