Results 1 to 6 of 6
Thread: main fuse box
    Aug 2007
    129
    main fuse box
    Hey guys,what is this wire??Its hooked up to the ignition coil fuse (F).Why is this wire like this?As some of you know I am trying to figure out my wiring.The one is the red with the green tracer,take a look at the picture.Thanks as always,JDC
    Sep 2009
    151
    Quote Originally Posted by JDC View Post
    Looks like someone wanted a switched power source to me. I could be wrong though. Are there any lights, a cd player or anything that turns on when you turn on your car? Find where the black wire goes, and theres your answer.
    May 2004
    Va. Beach,Va.
    7,136
    That should be the ignition wire that hot when the key is turned on. That's the wire that most people hook their i/c fan to.
    SCCOA Member #2406
    '94 SC AUTO - 2.3 Whipple
    Aug 2007
    129
    main fuse box
    No it does'nt hook up to anything it just makes a "ue"and then attached to its self. I thought at one time I read a thread on sccoa Teck about it.oh well I thought I would see if someone knew before I take it to a shop. Thanksfor the come back guys. JDC
    May 2004
    Va. Beach,Va.
    7,136
    The red wire with the green stripe should be the one that's hot when you turn the key on. The splice was probably used to hook up an accessory item that would turn on when the key was on. Instead of removing it when the accessory item was removed they probably just looped it into itself. Check it with a test light and see if it's hot when the key is on then you'll know.
    SCCOA Member #2406
    Aug 2007
    129
    main fuse box
    Hey there young man thanks for the come back.I have a thread on my 90 SC about the wiring problem I'm having. It's on the 2nd page at the bottom of the page. I can't get a test light to work to work even with the battery hooked up. The only thing that will light up is the starter and the alternator.The lights on the dash do'nt light up nothing else lights up except the starter and alternator.I'm going Tuesday to get a chiltons at the library to look at the wiring diagram maybe I can see what is what.I've looked at other sites and I got to pay for the wiring diagram so.. .Thanks for the come back.JDC ps. I'm learing how to use this computor so thats why the pitcure is'nt so good and I'm learing about this SC. JDC
  1. Fuse box question HELP
    By boogiedown27 in forum Technical Forum
    Last Post: 12-05-2009, 06:16 PM
  2. Continued ABS woes (and others)
  3. Need main fuse box for my Tbird
    By klh6uga in forum Want to Buy
    Last Post: 04-21-2007, 06:46 PM
  4. is it possible for a fuse box to go bad?
    By wigglesrewind in forum Technical Forum
    Last Post: 05-28-2005, 10:56 AM
