Results 1 to 13 of 13
Thread: Head gaskets!
    Oct 2009
    36
    Question Head gaskets!
    1995 3.8, NAPA doesn't carry them, they tell me that head gaskets are not even carried by the Dealer any more.
    If you have a source I'd love to hear from you.
    Dan
    BTW: I can't access the FAQ section; it says "Private" even though there are hundreds of threads there. Am I too new?
    Jul 2003
    Ottawa, Ohio
    5,436
    Advance Auto Parts and Autozone carry the FelPro headgaskets.
    PS: To access those private threads, you must pay $15 for a membership.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Philly
    2,439
    Dan,
    I just looked on Advance Auto parts and found them in stock. The part number is Fel Pro 1011-2
    I hope this helps
    Ken
    Quote Originally Posted by 914Driver View Post
    Dan
    1992 Thunderbird SC
    13.322 @ 102.81
    1993 Thunderbird SC 5spd..white
    2002 F350 SD Diesel (SC tow vehicle)
    Oct 2009
    36
    Thanks guys! I'm having a Merry Christmas in the garage, hoping the same for you!
    Dan
    May 2007
    Wichita, KS
    3,018
    yours is 3.8... na or is your car an sc?
    for an sc, if you plan to mod it later down the road, you might want to check out mls head gaskets, and arp studs.
    Oct 2009
    36
    Stock except for the cam. An SC specific parts supplier wants $135 for the top end gasket kit, Auto Zone gets $82. Head gaskets, intake, exhaust, valve seals, etc., etc.
    Dan
    Boston, MA
    7,483
    You need head bolts you cannot reuse the stock ones, Autozone has the kits. Alternative is ARP and are then reusable.
    You can go with composite HG or MLS like stated. If you are planning to go up and boost and future plans better do it right and get the MLS permatorque and ARP head bolt kit.
    Oct 2009
    36
    Thanks, I didn't know head bolts were not reusable.
    It's a steep learning curve.....
    Dec 2003
    Beaumont, TX
    741
    I suggest you do a search on "head gaskets", there a hundreds of threads on replacing headgaskets and what all is involved . I did my first HG job in a apartment complex parking lot with a Haynes manual. Haynes manual is generic but is very useful and lists the torque values. Goodluck.
    Thomas
    Oct 2009
    Spokane Wa
    1,209
    napa sells fel-pro also. if they tell you different just go to www.NAPAonline.com you can look up your own stuff.
    did you try rock auto yet.
    Apr 2007
    New Orleans, LA
    1,967
    head gaskets are a joke on the supercoupes now, i can get 'er done in 8 hours flat remove, repair, replace
    that even includes the time it take me to resurface them with a low enough RA for mls gaskets, pressure check, and sandblast.
    copper spray is your friend you'll need to spray the deck and the heads, don't worry about getting the cylinder walls and pistons it'll burn off
    the mls gaskets have a rivet that gets in the way, you'll need to drill it out, you'll see which rivet it is quick it won't let the head sit flush.
    arp head studs for the gm 2.8 v6 fits close enough to use them
    arp 233-4003 $84 summitracing.com
    in 97 ford swapped all there windsor v6s to the mls gaskets to prevent the common failures they were having. Back in the 90s we were resurfacing and revalving about 6 sets a day for the dealerships.
    step in the autoparts store and get the gaskets for a 97 f150 4.2 v6.
    9250-pt driver side, 9253-pt passenger side
    autozone usually has them the cheapest, the price just reduced FYI
    don't forget the o2 sensors are probably toast, ntk sensors last longer than bosch and are only a few bucks more, stock is 3 wire
    might as well get a bhj balancer while your at it, $350 for the SFI shoot me a PM if you need one
    Boston, MA
    7,483
    Quote Originally Posted by decipha View Post
    I would get the mustang ones better then the truck ones. Your post is accurate before we found the mustang Felpro MLS had a rubber lining on them.
    Oct 2009
    36
    Thanks, the engine is out of the car and on a stand, much easier. Once reassembled it will go into a 1968 Ford Cortina with a T5 .
    I'll put up pictures as I go.
    Dan
  1. New Heads instead of Machine Work? Head Gaskets Went
    By LXSC in forum Technical Forum
    Last Post: 06-06-2004, 08:59 AM
  2. Thoughts on SC Over Heating/Blown Head Gaskets?
    By discipled1 in forum Technical Forum
    Last Post: 05-30-2004, 12:38 AM
  3. head gaskets question
    Last Post: 05-05-2004, 08:50 PM
  4. My Head gaskets!
    By z9_87 in forum Technical Forum
    Last Post: 04-27-2003, 09:56 PM
  5. Head gaskets now when doing valve cover gaskets?
    By JAFO in forum Technical Forum
    Last Post: 10-22-2002, 02:00 PM
