Results 1 to 15 of 19
Thread: New 6R80 transmission...
    Memphis, TN
    1,911
    Anyone else think about the possibility of mating on of these to our engine? I love the thought of a 6-spd auto in an SC.
    7,570
    Does the aftermarket offer a stand-alone controller for it yet? That would probably be the biggest hurdle I think.
    cheers
    Ed N.
    Memphis, TN
    1,911
    Looks like FAST makes something that might work, and I saw a couple others that may work as well. The gear ratios in the 6R80 are as follows:
    4.17, 2.34, 1.52, 1.14, 0.87, 0.69
    Biggest hurdle I see is figuring out what rear end ratio to run with the thing. A 2.73 would be equivalent to having a 4.10 out back of a 4R70W in gears 1-3. Not bad if you cross the traps under 115mph and can rev to at least 6250 rpm.
    Guys like David, Chris, or Kevin running 125mph+ trap speeds could get away with a 3.27 at the cost of shifting into 4th, but 1st-3rd gear would blow the tires off with a 13.63:1 final drive ratio. That's like a 4.80 rear gear!!
    Oh well... maybe it's not such a good idea after all.
    Madison, Ohio
    17,574
    Quote Originally Posted by Pablo94SC View Post
    Gear ratio's are the last worry. Bolting it up to your 3.8L would be by far the biggest challenge.
    Email me here.
    Nov 2004
    butler pa
    1,926
    as power levels go up you don't need as many gears. that is why i want/am going to a powerglide (just 2 forward gears)
    https://www.youtube.com/watch?v=7bNS...e_gdata_player 10.070 video
    Best ET to date 10.070
    Best MPH to date 130.51
    best 60' to date 1.312
    MPX blower/ NO NITROUS!
    Aug 2005
    Chesapeake, VA
    1,976
    Quote Originally Posted by Kevin Leitem View Post
    I have been thinking about going with a C4.............
    NYC
    17,430
    What he said
    Nov 2004
    Brantford, ON
    5,383
    Quote Originally Posted by Roadhawg View Post
    With the advances they have with the AOD's and how tough those things are becoming (I've read easily over 800rwhp now) I'd get a built up one and at least have the OD when cruising along. Later vehicles with the 4r70w's are also up there when using a more modern one.
    I don't think there is anyone in the club running high enough power with the v6 that can out run a properly built up AOD/4r70w.
    Fraser
    Madison, Ohio
    17,574
    Quote Originally Posted by fturner View Post
    Fraser
    It's not about power handling. C4's have no advantage in that department. Where the C4 has an advantage is that it is lighter, cheaper to build, and has less internal frictional loss compared to an AOD type trans.
    Email me here.
    Memphis, TN
    1,911
    Good point Kevin. You wouldn't have use for this and I don't know if the rest of the high power guys do enough daily driving for this to be of any benefit.
    20,939
    Fraser
    I agree, but only if the car is mostly street driven and doesn't exceed a 1000 HP. For an SC of average weight that is mainly driven on the track or is making more than a 1000 HP (at the crank), I'd use a built TH400. From everything I've read, the C4 won't last very long in a high powered car that weighs more than 3000 lbs. Even the high powered mustang guys think their cars are too heavy for a C4, and the majority of guys with more than 650 rwhp use either a TH400 or a Glide.
    Oct 2006
    va beach,va
    2,584
    C4 has the Advantages Dave mentioned. Mostly less power robbing. They do fail quite often though. Even the fully built ones...Usually input shaft failure....And they were replaced with Th400's and never touched again....One of my friends even put a bowtie with a Ford emblem in it, on the rear window of his SN-95. Under it said "Dazed and Confused". I didnt care as long as we didnt have to pull the Art Carr C4 out again...
    Nov 2004
    Brantford, ON
    5,383
    I thought that is what they made arc welders for .
    Fraser
    Jan 2003
    Woodbridge, VA
    5,143
    Found the gear ratios for the 6r75. And some comparison numbers of other tran's
    6R75............................4.17 2.34 1.52 1.14 0.87 0.69 Thats one hellofa 1st gear.
    4R70W................................2.84 1.55 1.00 0.70
    AOD....................................2.40 1.47 1.00 0.67
    C4......................................2.46 1.46 1.00
    M5R2............................3.75 2.32 1.43 1.00 0.75
    M5R2-C.........................3.42 2.16 1.34 1.00 0.75
    And I see Ricardo is building tran's for ford. 6 Speed manual. Looks like a good one too.
    Ricardo 6...........2.611 1.708 1.233 0.943 0.767 0.625
    Pulled these numbers for this site Ford trans ratios
    ~Chris
    SCCoA Member #1826
    Bettie Riding jack stands
    SCARlit on drag duty now
    Jul 2003
    Eastern (nee Western) PA
    4,993
    Fraser
    Sounds like a dare!
    God bless!!!
    Former Birds:
  1. I found this FAQ on the SC
  2. Automatic Transmission install issues
    By XxSlowpokexX in forum Non Technical Forum
    Last Post: 02-12-2009, 11:40 AM
  3. 92 SC w/ Rebuilt Auto Transmission (#3)
    By jeffleeismyhero in forum Technical Forum
    Last Post: 03-02-2006, 10:06 AM
  4. My New Transmission Is Gone!
    Last Post: 08-14-2003, 02:21 AM
