Porting an MPX.
ricardoa1
So still in a tough place to make a decision on what blower to run. As some know, I am an MPX case away from having a complete M90 set up, but I am also a set of rotor bearings/seals away from being able to use the M112 hybrid thats currently down.
So I got the idea of saving the money I will spend on the blower and run the MPX case from the M112. Problem is that the case has been ported to make better use of the M112 rotors. I am unsure what will happen if use the M90 rotors on this case. Rotor opening timing was increased and the oulet was enlarged, but I was careful to not ruin the timing seal between the outlet and inlet.
What do you think will happen if I use this case. Will it be a better performing blower in the higher RPMS? Or is the porting now excessive for the M90 rotors.
Using this case will allow me so put money towars the exhaust system.
